SOLVED Menu screens with touch LCD screen-only working once
I am new to everything coding and arduino and have taught myself everything I know so far from online tutorials so my code may not be entirely efficient, but hopefully understandable-although any tips would be appreciated.
I am trying to make a menu with an LCD touchscreen with a settings button to take the user to a settings screen. On the settings screen there is a back button to the main menu. I have not activated any other buttons at this stage to keep it more simple as I build my code. Upon uploading the sketch the settings button takes the user to the settings menu as required, the back button then takes the user back to the main menu. However this only happens once. The settings button while it is highlighting as though it is selected does not take the user back to the settings screen for a second time, only initially after sketch upload.
I have included my code, the parts to make the screens I haven't commented yet or tidied so there may be some redundancies there that I haven't fixed yet.
Thanks in advance
int currentPage;
int pressedButton;
int Settings;
int Back;
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
sensors.begin();
rtc.begin();
mainScreen();
currentPage=0;
if(myTouch.dataAvailable()==true){        //check if touch screen has been touched
  pressedButton=myButtons.checkButtons();   //which button pressed?
  if(currentPage==0){                         //if currently on main menu (page 0)
    if(pressedButton==Settings){              //if the button selected is Settings
      myGLCD.clrScr();                        //clear LCD Screen
      settingsScreen();                       //Write the settings screen
      currentPage=1;                          //Change current screen to settings screen (Page 1)
   if(currentPage==1){                         //if currently on settings menu (page 1)
   if(pressedButton==Back){                    //if the button selected is Back
      mainScreen();                            //Write the main screen
      currentPage=0;                           //Change current screen to settings screen (Page 0)
void mainScreen(){
String DOW;
String Date;
String t;
DOW=rtc.getDOWStr(FORMAT_LONG);
Date=rtc.getDateStr(FORMAT_SHORT);
t=rtc.getTimeStr(FORMAT_SHORT);
float temp;
sensors.requestTemperatures();
temp=sensors.getTempCByIndex(0);
myGLCD.setBackColor(VGA_SILVER);
myGLCD.setColor(VGA_NAVY);
myGLCD.fillScr(VGA_SILVER);
myGLCD.setFont(GroteskBold16x32);
myGLCD.print(DOW,10,10);
myGLCD.setFont(Grotesk16x32);
myGLCD.print(Date,10,40);
myGLCD.print(t,10,70);
myGLCD.print("6.6",215,10);
myGLCD.print("38%",215,65);
myGLCD.printNumF(temp,1,215,125);
myGLCD.print("2.2",215,180);
myGLCD.setFont(SmallFont);
myGLCD.print("pH",170,10);
myGLCD.print("CO2",170,65);
myGLCD.print("temp",170,125);
myGLCD.print("flow",170,180);
myButtons.setTextFont(Grotesk16x32);
myButtons.setButtonColors(VGA_NAVY,VGA_WHITE,VGA_NAVY,VGA_RED,VGA_GRAY);
setBut=myButtons.addButton(10,150,140,70,"Settings");
myButtons.drawButton(setBut);
void settingsScreen(){
myGLCD.print("Settings",20,10);
setBackBut=myButtons.addButton(220,10,80,40,"Back");
setLightBut=myButtons.addButton(20,80,130,60,"Lights");
setCo2But=myButtons.addButton(20,160,130,60,"CO2");
setDosingBut=myButtons.addButton(170,80,130,60,"Dosing");
setOutletBut=myButtons.addButton(170,160,130,60,"Outlet");
myButtons.drawButton(setBackBut);
You don't assign values to Back and Settings so they're the same thing. Some weirdness may happen because you've chained the if statements such that when the main menu switches to settings, the next if is immediately run (because currentpage is now 1) etc.
Consider using a state machine for you menu system. It can help reduce error-inducing nesting of if/else statements, makes adding features later easuer and makes the code generally cleaner over all.
Do this behave more as you expect?
int currentPage;
int pressedButton;
const int Settings = x; //SHOULD ASSIGN SOMETHING TO THESE
const int Back = y;
    myGLCD.InitLCD();
    myGLCD.clrScr();
    sensors.begin();
    rtc.begin();
    mainScreen();
    currentPage=0;
void MenuStateMachine( int button )
    switch( currentPage )
        case    0:
            if( button == Settings )
            }//if
        case    1:
            if( button == Back )
            }//if
    }//switch
}//MenuStateMachine
    if(myTouch.dataAvailable() == true)
        MenuStateMachine( myButtons.checkButtons() );
}//loop
void mainScreen()
    String DOW;
    String Date;
    String t;
    float temp;
Thank you for your reply. I had tried a switch before and it didn't work, although i like how you comment for each close of the curly brackets to keep track of them- I will do this in the future. One mistake that I had in the code is inconsistencies with the names of those variables as I changed the names for ease of use in the forum. The UFT Buttons library assigns an integer to those values when it creates a button is my understanding. However I also tried giving these values as you suggested and it had the same outcome. Now though the menu is stuck on the settings menu and won't return to the main menu.
int setLightBut;
int setCo2But;
int setDosingBut;
int setOutletBut;
int currentPage;
int pressedButton;
int Settings=1;
int Back=2;
myGLCD.InitLCD();
myGLCD.clrScr();
sensors.begin();
rtc.begin();
mainScreen();
currentPage=0;
        case    0:
            if( pressedButton == Settings )
            }//if
        case    1:
            if( pressedButton == Back )
            }//if
    }//switch
}//MenuStateMachine
}//loop
void mainScreen(){
String DOW;
String Date;
String t;
float temp;
[b]Settings=myButtons.addButton(10,150,140,70,"Settings");[/b]
myButtons.drawButton(Settings);
[b]Back=myButtons.addButton(220,10,80,40,"Back");[/b]
myButtons.drawButton(Back);
myButtons.drawButton(setLightBut);
myButtons.drawButton(setDosingBut);
myButtons.drawButton(setCo2But);
myButtons.drawButton(setOutletBut);
Ah, okay. I see there where the value of Settings and Back are created.
Which touch library are you using? It seems like there's some stuff (e.g. includes) missing from your listing.
You call 'MenuStateMachine' by passing the pressed button as parameter.
  if (myTouch.dataAvailable() == true)
In 'MenuStateMachine' you test 'pressedButton' (which is unassigned) in stead of 'button' wich is passed over....
  switch ( currentPage )
    case    0:
      if ( pressedButton == Settings )
leongjerland:
    case    0:
Damn. Good catch. Fixed...
Here is the entire code. I don’t quite understand the correction that was made by leongjerland just there, if someone could explain please. This has all the libraries in there now, sorry I didn’t include them properly before. There are parts to the code that are not being used and some constants remaining from where I have tried different methods to get the buttons to work in the first place that I haven’t cleaned up yet.
#include <URTouch.h>
#include <UTFT_Buttons.h>
#include <memorysaver.h>
#include <UTFT.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DS3231.h>
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t Dingbats1_XL[];
extern uint8_t GroteskBold24x48[];
extern uint8_t CalibriBold32x48[];
extern uint8_t GroteskBold16x32[];
extern uint8_t Grotesk16x32[];
UTFT myGLCD(ILI9341_16,38,39,40,41);
//Temp
#define ONE_WIRE_BUS 8
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//RTC
DS3231 rtc(SDA,SCL);
//Touch Screen
URTouch myTouch(6,5,4,3,2);
UTFT_Buttons myButtons(&myGLCD,&myTouch);
int x;
int y;
int setLightBut;
int setCo2But;
int setDosingBut;
int setOutletBut;
int currentPage;
int pressedButton;
int Settings=1;
int Back=2;
myGLCD.InitLCD();
myGLCD.clrScr();
sensors.begin();
rtc.begin();
mainScreen();
currentPage=0;
void MenuStateMachine( int pressedButton )
        case    0:
            }//if
        case    1:
            }//if
    }//switch
}//MenuStateMachine
}//loop
void mainScreen(){
String DOW;
String Date;
String t;
float temp;
void lightScreen(){
  myGLCD.clrScr();
  myGLCD.setFont(GroteskBold24x48);
  myGLCD.print("LIGHTS",CENTER,100);
void co2Screen(){
  myGLCD.clrScr();
  myGLCD.print("CO2",CENTER,100);
void dosingScreen(){
  myGLCD.clrScr();
  myGLCD.print("Dosing",CENTER,100);
void outletScreen(){
  myGLCD.clrScr();
  myGLCD.print("Outlets",CENTER,100);
I have worked out now what leongjerland corrected in the first instance, so don’t worry about answering that question now.
I can’t work out why this isn’t working. I have gone through the entire code to find the issue. Here is the new version with more notes so it is clearer.
My understanding of the switch is as follows:
MenuStateMachine( myButtons.checkButtons() ); //calls the state machine and assigns the variable pressedButton (the integer variable assigned in the bracket when defining the function) as the checkButton
switch (currentPage) // analyses the currentPage variable to check against the cases (set as 0 in void setup- main screen)
Case 0: //when currentPage=0 (MainScreen) runs the code following
if( pressedButton == MainSettings ) // so if the button was the settings button code continues
myGLCD.clrScr();
settingsScreen();
currentPage=1; //clears screen, writes settings screen, changes current page variable to 1
case 1: //when currentPage=1 (settings screen) runs code
if( pressedButton == SettingsBack ) // if the button pressed was the back button runs code
myGLCD.clrScr();
mainScreen();
currentPage=0; //clears screen, writes menu screen, changes current page to 0
so I don’t understand why the settings button doesn’t work when I return to the home screen, because the last line in the case 1 is returning current page to 0 therefore should work with case 0 again. I have no idea where I have gone wrong. Everything works when the code has been uploaded just not once it’s gone through everything once.
currently this is what happens
code uploaded>>>
Main screen shows
selects Settings button
Setting Screen shows
selects Back Button
Main Screen Shows
stays on main screen-
the button has a red border when selected so I know it is recognising the touch but it is doing nothing with it
#include <UTFT.h>
#include <DS3231.h>
//Temp
//RTC
//Touch Screen
//Buttons on Setting Screen
int SettingsLight;            //Button on Settings screen for light
int SettingsCO2;              //Button on Settings screen for CO2
int SettingsDosing;           //Button on Settings screen for Dosing
int SettingsOutlet;           //Button on Settings screen for Outlet
int SettingsBack;             //Button on Settings screen to go back to home screen
//Buttons on Main Screen
int MainSettings;             //Button on Main Screen for Settings
//variables for progressing page
int currentPage;
//Screen Numbers
//Main Screen = 0
//Settings Screen = 1
myGLCD.InitLCD();                           //initialising LCD
myGLCD.clrScr();
myTouch.InitTouch();                        //initialising Touch
sensors.begin();                            //Starting Temp Sensor
rtc.begin();                                //Starting RTC
mainScreen();                               //Draw Home Screen
currentPage=0;                              //Set Current Page to 0 (main Screen)
}//loop
        case    0:
            }//if
        case    1:
            }//if
    }//switch
}//MenuStateMachine
//Drawing Screens
//Main Screen
void mainScreen(){
String DOW;                       //set variable for Day Of Week
String Date;                      //set variable for Date
String t;                         //set variable for Time
float temp;                       //set variable for Temperature
//collecting info from RTC
DOW=rtc.getDOWStr(FORMAT_LONG);         //info for DOW
Date=rtc.getDateStr(FORMAT_SHORT);      //info for Date
t=rtc.getTimeStr(FORMAT_SHORT);         //info for Time
//collecting info from temp sensor
sensors.requestTemperatures();          //get info from sensor
temp=sensors.getTempCByIndex(0);        //put temp info into variable
//set background and Date/time info
//print data ph/Co2/temp/flow
//create settings button
MainSettings=myButtons.addButton(10,150,140,70,"Settings");
myButtons.drawButton(MainSettings);
//Draw Settings Screen
//Background and Title
//Drawing Buttons
SettingsBack=myButtons.addButton(220,10,80,40,"Back");
SettingsLight=myButtons.addButton(20,80,130,60,"Lights");
SettingsCO2=myButtons.addButton(20,160,130,60,"CO2");
SettingsDosing=myButtons.addButton(170,80,130,60,"Dosing");
SettingsOutlet=myButtons.addButton(170,160,130,60,"Outlet");
myButtons.drawButton(SettingsBack);
myButtons.drawButton(SettingsLight);
myButtons.drawButton(SettingsDosing);
myButtons.drawButton(SettingsCO2);
myButtons.drawButton(SettingsOutlet);
void lightScreen(){
  myGLCD.clrScr();
void co2Screen(){
  myGLCD.clrScr();
  myGLCD.clrScr();
  myGLCD.clrScr();
Each time you run mainScreen() and settingsScreen() you create a new button (MainSettings and SettingsBack). I get the feeling that when a screen is destroyed (e.g. main, moving from main to settings) that all buttons should be deleted and new ones created. You already create new ones; how about adding destruction calls like
#include <UTFT.h>
#include <DS3231.h>
//Temp
//RTC
//Touch Screen
//Screen Numbers
//Main Screen = 0
#define SCRN_MAIN           0
#define SCRN_SETTINGS       1
int currentPage;
    myGLCD.clrScr();
    currentPage=SCRN_MAIN;                      //Set Current Page to 0 (main Screen)
}//setup
}//loop
void MenuStateMachine( int Btn )
    //checkButtons returns -1 if there's no button press available
    if( Btn == -1 )
        return;
        case    SCRN_MAIN:
            if( Btn == MainSettings )
                myButtons.deleteAllButtons();           //clear all existing buttons
                currentPage = SCRN_SETTINGS;            //Change current screen to settings screen (Page 1)
            }//if
        case    SCRN_SETTINGS:
            if( Btn == SettingsBack )
                currentPage = SCRN_MAIN;                 //Change current screen to settings screen (Page 0)
            }//if
    }//switch
}//MenuStateMachine
//Drawing Screens
//Main Screen
void mainScreen()
}//mainScreen
    //Drawing Buttons
}//settingsScreen
void lightScreen()
    myGLCD.clrScr();
}//lightScreen
void co2Screen()
    myGLCD.clrScr();
}//co2Screen
void dosingScreen()
    myGLCD.clrScr();
}//dosingScreen
void outletScreen()
    myGLCD.clrScr();
}//outletScreen
THAT WAS IT!!!!!!!
Thank you so much!!! I've been racking my brain for hours!
