[SOLVED] MKR Ethernet TCP Connection with Horsepower Sensor
Hello everyone -
I’ve had a few years experience with programming Arduino microcontrollers, but I still consider myself a novice. I’m currently using the MKR 1400 GSM with an MKR ETH shield to capture data from the LittleFuse MP8000 horsepower sensor. The MKR board/shield and sensor are connected via Ethernet cable. The sensor’s programming guide explicitly states:
“The RJ45 jack on the side of the MP8000 is the interface for MODBUS TCP and Ethernet/IP. The user can access the MP8000 via a network or via a direct connection.”
The sensor’s point-to-point configuration guide (attached) provides the IPv4 ip address and subnet mask in order to make the direct connection.
You can probably tell where I’m going with this. When I set up an Ethernet Client to connect to the Modbus TCP Server, it fails. I’ve tried all sorts of combinations of client/servers, ports, and Ethernet libraries to get the two to pair, but nothing gives.
Code here:
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
//Enter a MAC address and IP address for your controller below.
//The IP address will be dependent on your local network.
//gateway and subnet are optional:
byte MKRETHmac[] = { 0xEC, 0xF4, 0xBB, 0x40, 0x33, 0x1D };
byte MKRETHip[] = { 10, 106, 0, 1 };
byte MP8000mac[] = { 0x00, 0x21, 0x6F, 0x00, 0x49, 0xB5 };
byte MP8000ip[] = { 10, 106, 0, 1 };
byte MP8000subnet[] = { 255, 255, 0, 0 };
byte gateway[] = { 192, 168, 0, 1 };
byte dns[] = { 1, 1, 1, 1 };
EthernetClient ethernetclient;
ModbusTCPClient modbusTCPclient(ethernetclient);
//disable the SD card
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
//initialize the ethernet shield
Ethernet.init(5); // MKR ETH shield
Ethernet.begin(MKRETHmac, MKRETHip, dns, gateway, MP8000subnet);
delay(3000);
while (!Serial); {}
//Start Modbus TCP and Ethernet client connections
modbusTCPclient.begin(MP8000ip, 502);
ethernetclient.connect(MP8000ip, 502);
if (ethernetclient.connected()) {
    Serial.println("Ethernet Client Connected!");
    char c = ethernetclient.read();
    Serial.print(c);
       Serial.println("Ethernet client failed to connect!");
       Serial.print("Local IP Address: ");
       Serial.println(Ethernet.localIP());
       Serial.print("DNS Server IP Address: ");
       Serial.println(Ethernet.dnsServerIP());
       Serial.print("Gateway Address: ");
       Serial.println(Ethernet.gatewayIP());
       Serial.print("Subnet Mask Address: ");
       Serial.println(Ethernet.subnetMask());
if (modbusTCPclient.connected()) {
    Serial.println("Modbus TCP client connected!");
       Serial.println("Modbus TCP client failed to connect!");
       Serial.println(modbusTCPclient.lastError());
void loop() {}
and serial monitor output here:
Local IP Address: 10.106.0.1
DNS Server IP Address: 1.1.1.1
Gateway Address: 192.168.0.1
Subnet Mask Address: 255.255.0.0
Any help?
MP8000_Point_to_Point_Configuration.pdf (927 KB)
did you try it over a switch or router?
The Arduino and the MP8000 cannot use the same IP address. I would configure the MP8000 to 10.106.0.2.
In point to point mode, the gateway and dns should be left unspecified since they are not used.
I have never used MODBUS so that is all I can comment on.
@Juraj I’m trying the connection over direct Ethernet cable between the MP8000 and MKR ETH shield. Picture of setup attached.
@gbafamily that was my initial thought, too. I plugged my laptop into the MKR ETH shield to find its IP address and then did the same for the MP8000. Using those IP Addresses made no difference.
cjtate14:
for direct connection:
  1. use crossed cable
  2. you are responsible to set the IP addresses in this network with two devices
Problem solved! The MP8000 just needed a firmware update. Lights on the sensor changed to indicate data transmission and the serial monitor reported successful connection.
Thanks for the help anyway!
