#include <SimpleModbusSlave.h>
/* This example code will receive the adc ch0 value from the arduino master.
It will then use this value to adjust the brightness of the led on pin 9.
The value received from the master will be stored in address 1 in its own
address space namely holdingRegs[].
In addition to this the slaves own adc ch0 value will be stored in
address 0 in its own address space holdingRegs[] for the master to
be read. The master will use this value to alter the brightness of its
own led connected to pin 9.
The modbus_update() method updates the holdingRegs register array and checks
communication.
Note:
The Arduino serial ring buffer is 128 bytes or 64 registers.
Most of the time you will connect the arduino to a master via serial
using a MAX485 or similar.
In a function 3 request the master will attempt to read from your
slave and since 5 bytes is already used for ID, FUNCTION, NO OF BYTES
and two BYTES CRC the master can only request 122 bytes or 61 registers.
In a function 16 request the master will attempt to write to your
slave and since a 9 bytes is already used for ID, FUNCTION, ADDRESS,
NO OF REGISTERS, NO OF BYTES and two BYTES CRC the master can only write
118 bytes or 59 registers.
Using a USB to Serial converter the maximum bytes you can send is
limited to its internal buffer which differs between manufactures.
#define LED 9
// Using the enum instruction allows for an easy method for adding and
// removing registers. Doing it this way saves you #defining the size
// of your slaves register array each time you want to add more registers
// and at a glimpse informs you of your slaves register layout.
//////////////// registers of your slave ///////////////////
enum
// just add or remove registers and your good to go...
// The first register starts at address 0
ADC_VAL,
PWM_VAL,
HOLDING_REGS_SIZE // leave this one
// total number of registers for function 3 and 16 share the same register array
// i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
/* parameters(HardwareSerial* SerialPort,
long baudrate,
unsigned char byteFormat,
unsigned char ID,
unsigned char transmit enable pin,
unsigned int holding registers size,
unsigned int* holding register array)
/* Valid modbus byte formats are:
SERIAL_8N2: 1 start bit, 8 data bits, 2 stop bits
SERIAL_8E1: 1 start bit, 8 data bits, 1 Even parity bit, 1 stop bit
SERIAL_8O1: 1 start bit, 8 data bits, 1 Odd parity bit, 1 stop bit
You can obviously use SERIAL_8N1 but this does not adhere to the
Modbus specifications. That said, I have tested the SERIAL_8N1 option
on various commercial masters and slaves that were suppose to adhere
to this specification and was always able to communicate... Go figure.
These byte formats are already defined in the Arduino global name space.
modbus_configure(&Serial, 9600, SERIAL_8N2, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
pinMode(LED, OUTPUT);
// modbus_update() is the only method used in loop(). It returns the total error
// count since the slave started. You don't have to use it but it's useful
// for fault finding by the modbus master.
modbus_update();
holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
analogWrite(LED, holdingRegs[PWM_VAL]>>2); // constrain adc value from the arduino master to 255
/* Note:
The use of the enum instruction is not needed. You could set a maximum allowable
size for holdinRegs[] by defining HOLDING_REGS_SIZE using a constant and then access
holdingRegs[] by "Index" addressing.
I.e.
holdingRegs[0] = analogRead(A0);
analogWrite(LED, holdingRegs[1]/4);
You configure your Arduino to communicate with 9600 baud but in the software on your PC you configure 38400 baud. Do you really expect that they understand each other?
SimpleModbusSlaveArduino.cpp: In function 'void setup()':
SimpleModbusSlaveArduino:79: error: 'SERIAL_8N2' was not declared in this scope
I told you earlier that you should install the new IDE version but you seem to ignore almost anything I write. Do you want to get help or do you just want to complain a bit?
Have you changed the parameters so that the values on the PC and the Arduino match? Post the sketch you uploaded (exactly as you did, so not an external link) and new screenshots if you changed the parameters in the PC software.
Excuse me but your posts sound a bit like: "I connected my computer with a wall-socket but I don't get Internet".
ModBus is not (yet) a plug-and-play technology so you have dig a bit into the technology, read at least the basic documents and know the basics of the terminology. I'm definitely no expert in ModBus, I not even used one myself yet, but just from the readings I've done to evaluate a bus system for another project I seem to know much more about it than you who is using it.
Your sketch does not compile because Modbus is not defined. There is no include of a ModBus library nor is the code contained in the sketch. If you use a library tell us which one you use (if you already provided a link to it) or post the link if it's not yet in this topic.
Do you have access to a logic analyzer? If not, do you have an Arduino with more than one (virtual) serial interface (Mega, Leonardo, etc.)?
You PC program seems to only receive zeros from the ModBus. This is either a hardware problem (wrong wiring, defective adapter, etc.) or the sketch is not really running on the Arduino and the PC is interpreting that incorrectly.
I am planning to purchase below product from sparkfun . Since i found the Lot of issue building modbus circuit. Is there any library associated with below product.
AMPS-N:
No, because you don't need a specific library for this product. Even the read/write switch is implemented automatically, so you don't have to use pin 3 handling in your current code.
Intially i tried with chip it didn’t worked . SO i have now RS485 shield like sparkfun. IT stack on Arduino uno board. I am thinking here dont require schematic. You can also refer schematic in link provided itself.
I am getting Error for Every code i tried from forum. Every code successfully compile .
Error i have got as below:
could not able to receive data from slave
Slave through exception, improper CRC is implemented.
Here i am attaching all trial code which compile successfully. But above error.i think there no hardware issue i am using this shield. I am using Qmodbus software which acts as Master.
Is it like the one from Sparkfun or is it the one from Sparkfun? If it's not from Sparkfun, provide schematics for it.
I thought the Arduino should be the slave, so if you got this error on the Arduino, you loaded master code, which isn't expected to work here. If I misinterpreted you here, please be more specific about what you've done and what the result was. Most of the your previous posts gave me the impression that you want to hide some information from us and you're just complaining about a setup not working. If you don't give us the necessary information we cannot help you.
In the previous posts you never had a setup described that really matched the other side. For example, if you have different baud rates on the two sides of the communication you'll never get any real data through.
Did it really return a CRC or just zeros, in which case the transmission failed and not the CRC calculation.
That's a whole category of devices, not a specific one.
I'm still waiting for you to post a photograph of your setup (with all wiring visible). The make a screenshot of the Qmodbus software as you're trying with. And post the code you uploaded to the Arduino for the tests. This information has to show your setup and not a setup that you think you made your's a duplicate of.
It is from Sparkfun only.
I have uploaded the code of slave downloaded from various website. So i am trying to any one slave library(modified ) to get it worked on Arduino. Those files are attached in Previous
Posted on: April 07, 2014, 10:47:22 pm on this site.
yes i am getting all zero . the images also attached in previous threads.
These information already provided. Please refer previous thread in image. Previously tried with IC and it circuit attached in previous threads . Now instead of testing with IC i am using shield here. SO no point of posting picture.
You posted a diagram of how you think you wired it. Where humans work errors happen and as I suppose you are a human being...
We never saw a photograph of how you wired it. Experience shows that wiring problems are often seen so I usually cross check. I apologize if you are perfect and never fail.
time hh/mm/sec and date: dd/mm/ss format as follow. these are coming out in form DS1307
They are coming out in bits and bytes from the chip. If you are using a library you never told us which one and this information is relevant because there are dozens of libraries for this chip.
I have floating value like latitude=13.08 , i can read only 13 here .from master.
uint16_t au16data[9];
You defined the registers to be integers so why do you expect the master to read anything else?
i have connected analog device to port 0 , if tried to vary reading refelcted in master. one weird problem is if analog output is not change then also values being get updated in modbus. I have used simple potentiometer network.
I don't understand what the problem is. Do you mean that the read value changes although you didn't turn the potentiometer? How much does the value change? What circuit is connected (diagram or photo)?
i converted into decimal format.
that s reason i am trying to convert float value to integer parameter
Potentiometer working fine. it doesn't changes that much as it has offset of +1 v . initially it is +2v difference
