Hello,
I am working on an application in visual studio 2019 to control a 50 tonne hydraulic press. So far I have got visual studio to connect to the Arduino mega over a COM port and sends strings with the end line character '#' to the Arduino, which then drives certain pins HIGH/LOW to control SSR's, that in turn control the press.
while(Serial.available()>0)
c = Serial.read();
SerialData += c;
if(c=='#')//if an End Line Character Received
if(SerialData=="ON#")
{ digitalWrite(53, HIGH);
else if(SerialData=="OFF#"){
digitalWrite(53, LOW);
c=0;
SerialData="";
On the Arduino I am using the ModbusMaster library to talk to a 50 tonne load cell over Modbus RTU, it pulls the readout from the press to the Arduino, which is then sent back over the comport to Visual studio, this is done over Serial1.
ReadLoadCell = node.readInputRegisters(3, 3);
if(ReadLoadCell == node.ku8MBSuccess)
Current_Pressure = node.getResponseBuffer(0x02);
Serial.println(Current_Pressure);
Both parts of the code work on their own, but when they are combined the Arduino does not respond to the end line character commands from Visual Studio. It is receiving them as the Rx LED is flashing in when the commands are sent.
I have gone through the code and have isolated the problem to this single line. I do not understand why this line of code is interfering with the end of line commands?
I have an SSR hooked up to pin 53 for testing and when the line below is commented out the LED on the SSR shows it is working as intended.
Link to ModbusMaster Library ModbusMaster
Full code below.
//Global Variable
#include <ModbusMaster.h> //Library for using ModbusMaster
ModbusMaster node; //object node for class ModbusMaster
uint8_t ReadLoadCell;
long Current_Pressure;
char c;
String SerialData;
Serial1.begin(9600); //Baud Rate as 9600
node.begin(1, Serial1); //Slave ID as 1
pinMode(53,OUTPUT);
c = Serial.read();
SerialData += c;
c=0;
SerialData="";
//ReadLoadCell = node.readInputRegisters(0x30001, 03);
