[SOLVED]modulo wrong results
First time decide to use modulo "%" operator and got confused.
a=17
b=1
17%1=1 as per Arduino
but formula is a-b*(a/b)
so step1:17/1=17
step2:1*17=17
step3:17-17=0
from where that 1 is coming from ?
UPDATE: put 9/8 in brackets and figured out what was confusing me.
whole expression is:
(7+10)%9/8
I guess because of left to right rule as % and / have same precedence first its doing % then division
i.e.
17%9=8
then 8/8 =1
Always make clear what you are doing. Never make someone reading the code or the compiler guess what is going on.
I have even a problem with "%9/8", I would use one of these:
( 7 + 10 ) % ( 9 / 8 )
( ( 7 + 10 ) % 9 ) / 8
surepic:
What? Anything modulo 1 is zero. The C '%' is not a modulo operator, it is a remainder operator. This matters when you start using it with negative numbers. Anything divided by 1 is equal to itself with a remainder of zero.
