SOLVED More trouble with declaring/defining/initializing "complex" data structs
I posted a few days ago because I was getting an error message about "too many initializers" and some kind folks helped me then. I thought I was all set, because those error messages went away. But somehow, I wasn't paying attention to new warnings that were produced instead.
I am now getting a long series of warnings like this:
C:\Users\tastewar\Documents\Arduino\sketch_jan10a\sketch_jan10a.ino:50:1: warning: narrowing conversion of '16753920l' from 'long int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:\Users\tastewar\Documents\Arduino\sketch_jan10a\sketch_jan10a.ino:50:1: warning: large integer implicitly truncated to unsigned type [-Woverflow]
Here is my code which will compile and yield these errors:
#define RED          0x00FF0000
#define GREEN        0x0000FF00
#define BLUE         0x000000FF
#define PURPLE       0x00800080
#define YELLOW       0x00FFFF00
#define ORANGE       0x00FFA500
#define LUNCH        ORANGE
#define ASPIRE       ORANGE
#define OUTOFCLUSTER ORANGE
typedef struct _Period
  uint8_t  begH;
  uint8_t  begM;
  uint8_t  endH;
  uint8_t  endM;
  uint32_t aCol;
  uint32_t bCol;
  uint32_t cCol;
  uint32_t dCol;
} Period;
#define MAX_PERIODS 9
typedef struct _BellSched
  uint8_t NumPeriods;
  Period Periods[MAX_PERIODS];
} BellSched;
typedef struct _SingleDay
  uint16_t    Y;
  uint8_t     M;
  uint8_t     D;
  const BellSched*  dayType;
} SingleDay;
const PROGMEM BellSched NormalDay[]=
  9,
  { 8, 0, 8,50, OUTOFCLUSTER, RED,          OUTOFCLUSTER, YELLOW},
  { 8,52, 9,40, RED,          YELLOW,       YELLOW,       OUTOFCLUSTER},
  { 9,42, 9,52, ASPIRE,       ASPIRE,       ASPIRE,       ASPIRE},
  { 9,54,10,42, YELLOW,       OUTOFCLUSTER, RED,          RED},
  {10,44,11,32, GREEN,        OUTOFCLUSTER, BLUE,         GREEN},
  {11,34,12,23, OUTOFCLUSTER, BLUE,         GREEN,        PURPLE},
  {12,25,12,46, LUNCH,        LUNCH,        LUNCH,        LUNCH},
  {12,48,13,36, BLUE,         PURPLE,       PURPLE,       OUTOFCLUSTER},
  {13,38,14,26, PURPLE,       GREEN,        OUTOFCLUSTER, BLUE},
const PROGMEM BellSched ER1300[]=
  8,
  { 8, 0, 8,37, OUTOFCLUSTER, RED,          OUTOFCLUSTER, YELLOW},
  { 8,39, 9,16, RED,          YELLOW,       YELLOW,       OUTOFCLUSTER},
  { 9,18, 9,55, YELLOW,       OUTOFCLUSTER, RED,          RED},
  { 9,57,10,34, GREEN,        OUTOFCLUSTER, BLUE,         GREEN},
  {10,36,11,12, BLUE,         PURPLE,       PURPLE,       OUTOFCLUSTER},
  {11,14,12, 0, OUTOFCLUSTER, BLUE,         GREEN,        PURPLE},
  {12, 2,12,22, LUNCH,        LUNCH,        LUNCH,        LUNCH},
  {12,24,13, 0, PURPLE,       GREEN,        OUTOFCLUSTER, BLUE},
// days not present are either weekend days or holidays
const PROGMEM SingleDay TheCalendar[]=
  {2018,9,4,NormalDay},
  {2018,9,5,NormalDay},
  {2018,9,6,NormalDay},
  {2018,9,7,NormalDay},
  {2018,9,11,NormalDay},
  {2018,9,12,NormalDay},
  {2018,9,13,NormalDay},
  {2018,9,14,NormalDay},
  {2018,9,17,NormalDay},
  {2018,9,18,ER1300},
  {2018,9,20,NormalDay},
  {2018,9,21,NormalDay},
OK, so this suggests to me that the compiler and I are not on the same page. It's talking about my color definitions being truncated from 32 to 8 bits, but the structure definition clearly (well, to me :slight_smile: ) has them as 32 bits. So, my belief is that somehow, the initializers I have provided aren't getting mapped into the structures the way I think they should.
Also, while the solution I was given was to add the [] after my variable names, which did have the immediately desired effect, something tells me this still isn't right, because it states that my variables are arrays, and they're not. They shouldn't be arrays of BellSched's -- each variable should be a single BellSched.
But of course, if I remove the brackets, I'm back to the too many initializers problem.
What am I doing wrong??
You're missing a set of { and }. In BellSched, Periods is an array.
E.g. for NormalDay
const PROGMEM BellSched NormalDay[] =
  9,
    { 8, 0, 8, 50,   OUTOFCLUSTER, RED,          OUTOFCLUSTER, YELLOW},
    { 8, 52, 9, 40,  RED,          YELLOW,       YELLOW,       OUTOFCLUSTER},
    { 9, 42, 9, 52,  ASPIRE,       ASPIRE,       ASPIRE,       ASPIRE},
    { 9, 54, 10, 42, YELLOW,       OUTOFCLUSTER, RED,          RED},
    {10, 44, 11, 32, GREEN,        OUTOFCLUSTER, BLUE,         GREEN},
    {11, 34, 12, 23, OUTOFCLUSTER, BLUE,         GREEN,        PURPLE},
    {12, 25, 12, 46, LUNCH,        LUNCH,        LUNCH,        LUNCH},
    {12, 48, 13, 36, BLUE,         PURPLE,       PURPLE,       OUTOFCLUSTER},
    {13, 38, 14, 26, PURPLE,       GREEN,        OUTOFCLUSTER, BLUE},
If ER1300 and NormalDay don't have to be arrays, leave the [] out and modify TheCalendar to take the address of the variable using &
const PROGMEM SingleDay TheCalendar[] =
  {2018, 9, 4, &NormalDay},
  {2018, 9, 5, &NormalDay},
  {2018, 9, 6, &NormalDay},
  {2018, 9, 7, &NormalDay},
  {2018, 9, 11, &NormalDay},
  {2018, 9, 12, &NormalDay},
  {2018, 9, 13, &NormalDay},
  {2018, 9, 14, &NormalDay},
  {2018, 9, 17, &NormalDay},
  {2018, 9, 18, &ER1300},
  {2018, 9, 20, &NormalDay},
  {2018, 9, 21, &NormalDay},
Sharp eyes :slight_smile:
Thank you, sterretje! That was it.
I had just been doing more experimenting in another C environment, and was getting the same error, so had convinced myself it wasn't some weird Arduino quirk. And then I was playing around, and discovered that if I got rid of the inner braces around my Period initializers, that appeared to work. But your solution makes more sense, and also appears to work.
Yay! Thanks again!!
J-M-L:
Yes
But they took half an hour to get the focus right :frowning:
This works also. Follow the pattern. Also, you don't need the 'typedef' in C++:
#include "Arduino.h"
struct Period
 uint8_t begH;
 uint8_t begM;
 uint8_t endH;
 uint8_t endM;
 uint32_t aCol;
 uint32_t bCol;
 uint32_t cCol;
 uint32_t dCol;
struct BellSched
 uint8_t NumPeriods;
struct SingleDay
 uint16_t Y;
 uint8_t M;
 uint8_t D;
const BellSched dog PROGMEM = { 9, {
 { 8, 0, 8, 50, OUTOFCLUSTER, RED, OUTOFCLUSTER, YELLOW },
 { 8, 52, 9, 40, RED, YELLOW, YELLOW, OUTOFCLUSTER },
 { 9, 42, 9, 52, ASPIRE, ASPIRE, ASPIRE, ASPIRE },
 { 9, 54, 10, 42, YELLOW, OUTOFCLUSTER, RED, RED },
 { 10, 44, 11, 32, GREEN, OUTOFCLUSTER, BLUE, GREEN },
 { 11, 34, 12, 23, OUTOFCLUSTER, BLUE, GREEN, PURPLE },
 { 12, 25, 12, 46, LUNCH, LUNCH, LUNCH, LUNCH },
 { 12, 48, 13, 36, BLUE, PURPLE, PURPLE, OUTOFCLUSTER },
 { 13, 38, 14, 26, PURPLE, GREEN, OUTOFCLUSTER, BLUE } } };
EDIT:
Oh wait. Probably the same as @sterretje posted. Hard to count all those {{{ }}}.
Thanks, gfvalvo!
