task handle and semaphore are very very different things.
Yes, you can use taskhandles as a lightweight 'alternate' to semaphores. Enjoy.
thank you, im going thru some tutorials. your code seems much more intresting to me now thanks
I had a task that was jumping out of the for(; loop. I used a taskhandle to cause the task to restart, until I figured out the issue.
Idahowalker:
I had a task that was jumping out of the for(;loop. I used a taskhandle to cause the task to restart, until I figured out the issue.
i have this also ill try to change my code to use semaphores then
start a new thread and lets see the task and its creation method. How do you know the task is jumping the for( ; ; ). A log_i("task jumped ship"); would do the trick after the close of the for loop.
I take you are using vTasDelete( NULL ); after the for loop end?
Have you checked the HighWaterMark for stack space use?
Im in the middle of changing the code at the moment. I know it was jumping out because i would get some disconnects and some other funny stuff that i had to "correct" by using some extra bools like inuse=true or false etc
I am not using vTaskDelete(NULL) on any task.. should I? Wouldn't that delete the task and not run again? Im running all tasks "all the time",with some vTaskDelays....
No i havent checked how much stack im using, i increaed it a lot just to make it run and then fix it properly.
btw:
sema_MQTT_Parser = xSemaphoreCreateBinary();
sema_HistoryCompleted = xSemaphoreCreateBinary();
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_HistoryCompleted );
xSemaphoreGive( sema_MQTT_KeepAlive );
Why you xSemaphoreGive 2 Tasks?
thank you
If vTaskDelete(NULL) is after the for loop then vTaskDelete will never run, unless the task skips or goes beyond the for loop.
Humm. The question does not make much sense. Because those semaphores are protecting 2 different resources. It's how semaphores work. A semaphore token must be given before a token can be taken.
