[solved] Multiple Ultrasonic sensors and logic in programing them
I know there are other posts about this subject but I didn't find the answer I was looking for.
So I have a robot with 4 US sensors front, back, left and right. And right know I want the robot to drive until the obstacle is 10 cm away and then the robot should stop, just for testing. So my problem right know is that the robot only stops if the obstacle is in the way of the right US sensor but I want the robot to check the front first then back then left and last right, because I think it would be hard otherwise.
But I don't find my mistake in the programming there must be a logic error I made.
Would be glad if you guys could help me out.
The code is in the attachments.
#include <ArloRobot.h>
#include <SoftwareSerial.h>
ArloRobot Arlo;                                             // Arlo object
SoftwareSerial ArloSerial(12, 13);                  // Serial in I/O 12, out I/O 13
String directions[4] = {"Front:    ",                // Directions for display
                        "Back:     ",
                        "Left:     ",
                        "Right:    "
int pingPin[4] = {11, 10, 9, 8};                    // Ping pins
int cmDist[4];                                             // Cm distances
int i = 0;                                                    // Index, stat at 0
int countsLeft, countsRight;
  ArloSerial.begin(19200);                           // Start DHB-10 serial com
  Arlo.begin(ArloSerial);                              // Pass to Arlo object
  Arlo.clearCounts();                                   // Clear encoder counts
  cmDist[i] = pingCm(pingPin[i]);                //Get distance
  Serial.print(directions[i]);                         // Display direction
  Serial.print("cmDist[");                            // Display variable name
  Serial.print(i);                                         // Display variable index
  Serial.print("] = ");                                  // Display ] & =
  Serial.println(cmDist[i]);                          // Display value
  if (cmDist[i] >= 30)
    Arlo.writeSpeeds(72, 72);                      // Go forward 72 counts/sec
    Arlo.writeSpeeds(0, 0);
  delay(50);
  i++;
  if (i == 4)                                             // If index is 4
    i = 0;                                                 // Reset index to 0
    delay(50);                                          // Wait
    Serial.println();                                   // Print a blank line
int pingCm(int pin)                                 // Ping measurement function
  digitalWrite(pin, LOW);                        // Pin to output-low
  pinMode(pin, OUTPUT);
  delayMicroseconds(200);                     // Required between successive
  digitalWrite(pin, HIGH);                       // Send high pulse
  delayMicroseconds(5);                        // Must be at least 2 us
  digitalWrite(pin, LOW);                       // End pulse to start ping
  pinMode(pin, INPUT);                         // Change to input
  long microseconds = pulseIn(pin, HIGH);     // Wait for echo to reflect
  return microseconds / 29 / 2;              // Convert us echo to cm
Ultrasonic_Sensor.ino (2.56 KB)
Would be glad if you simply posted your code in code tags.
There is. You illogically assumed that you could post here without reading the directions.
Go read the stickies at the top of the forum that discuss how to post code properly AND how to ask intelligent questions.
I KNOW that your code doesn't look like that, but, because you didn't post it properly, it is impossible to determine what it actually looks like.
It appears that the right sensor is the last in the sequence.
Coincidence?
digitalWrite(pin, LOW);  Call me old-fashioned if you wish, but when I write to a pin, I like to think it is an output pin, and I'm not just waggling the pullup resistor on an input.
AWOL:
Coincidence?
I found the mistake I just added a delay before i++; and now I does work properly.
PaulS:
Sry I just glanced over the text. Next time when I post something in here I will post it properly.
