[SOLVED] My code stop to running
Hello,
I write the following code but this stop to run after the Serial.println("A");
It displays A and return in my serial monitor, and after then nothing. Even if I put another println after this.
.h
#ifndef LCD_h
#define LCD_h
class LCD{
  public:
    LCD(void);
    void firstLine();
    void secondLine(float tempInCelsius);
  private:
    LiquidCrystal_I2C lcd;
#endif
.cpp
#include "LCD.h"
LCD::LCD(void) : lcd(0x27, 16, 2){
    lcd.init();
    lcd.backlight();
    lcd.setCursor(0, 0);
void LCD::secondLine(float tempInCelsius){
    Serial.println("C");
    lcd.clear();
    lcd.setCursor(0, 1);
    lcd.print("T = ");
    lcd.print(tempInCelsius);
.ino
#include "LCD.h"
LCD CrystalLCD;
void setup(void)
    // Serial.begin(9600);
    Serial.println("B");
void loop(void)
    float temp = 1.40;
    CrystalLCD.secondLine(temp);
    lcd.init();
    lcd.backlight();
This constructor is being called at global scope BEFORE the init function sets up the hardware.
A constructor should just set up variable values and instantiate objects and that is all. Move all the stuff that relies on hardware like twiddling pins or playing with serial into a begin() or init() method that you can call from setup. So that's everything in the body of your constructor.
