Hello.
I have been trying to write my own first library, in a project I am using both ADCs and DACs amongst other things and I want to make classes for these and then why not put these classes in library’s?
I begun with the DAC MAX5216 a 16bit buffered voltage output SPI DAC, here are my files:
MAX5216.h:
#ifndef MAX5216_h
#define MAX5216_h
#include "Arduino.h"
// Class definition (this is a 'pre-declaration'.
class MAX5216
public:
MAX5216(int CSpin); // Constructor, save the slave select pin to private holder.
void begin(); // Initializes SPI settings to fit MAX5216.
void write_mV(int mVval); // To set DAC output with a milliVolts value, depends on actual DAC reference voltage.
void write_DEC(int DECval); // To set DAC output with a decimal value from 0 to 65535.
int read(); // Check what value the DAC is set to.
private:
void DAC_update(int code); // This makes the actual SPI transfer and it is called from both public write_ options.
int _CSpin; // Holder for slave select pin.
int _last; // Holder for the values send to DAC.
#endif
MAX5216.cpp:
#include "MAX5216.h"
#include "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI/SPI.h"
MAX5216::MAX5216(int CSpin)
_CSpin = CSpin;
void MAX5216::begin()
// MAX5216 DAC Setup
// MSB first, shifts data on SCKs falling edge, clock idle Low, SCK freq « 50MHz.
SPI.begin(_CSpin);
SPI.setBitOrder(_CSpin, MSBFIRST);
SPI.setDataMode(_CSpin, SPI_MODE1);
SPI.setClockDivider(_CSpin, 2);
void MAX5216::write_mV(int mVval)
if (mVval < 0)
mVval = 0;
else if (mVval > 3000)
mVval = 3000;
unsigned int code = 65535 * (mVval/3000.0);
DAC_update(code);
void MAX5216::write_DEC(int DECval)
if (DECval < 0)
DECval = 0;
else if (DECval > 65535)
DECval = 65535;
DAC_update(DECval);
int MAX5216::read()
return _last;
void MAX5216::DAC_update(int code)
_last = code;
uint32_t MAXcode = code << 6 | 0x400000;
byte byte1 = (MAXcode & ~(0x00FFFF)) >> 16; // Extraxt B23-B16
byte byte2 = (MAXcode & ~(0xFF00FF)) >> 8; // Extraxt B15-B8
byte byte3 = MAXcode & ~(0xFFFF00); // Extraxt B7-B1
SPI.transfer(_CSpin, byte1, SPI_CONTINUE); // Send B23-B16 through SPI
SPI.transfer(_CSpin, byte2, SPI_CONTINUE); // Send B15-B8 through SPI
SPI.transfer(_CSpin, byte3, SPI_LAST); // Send B7-B1 through SPI
But when compiling:
#include <MAX5216.h>
#include <SPI.h>
The compilation process(which maybe should be called something else) stops very early, the green progress bar is about half and all that shows is:
Using library MAX5216 in folder: C:\Users\David\OneDrive\Arduino\libraries\MAX5216 (legacy)
Using library SPI in folder: C:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\libraries\SPI
C:\Users\David\AppData\Roaming\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -MMD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=10604 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/libsam -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/CMSIS/Include/ -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/Device/ATMEL/ -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\variants\arduino_due_x -IC:\Users\David\OneDrive\Arduino\libraries\MAX5216 -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\libraries\SPI C:\Users\David\AppData\Local\Temp\build6335026798324731736.tmp\sketch_may28c.cpp -o C:\Users\David\AppData\Local\Temp\build6335026798324731736.tmp\sketch_may28c.cpp.o
C:\Users\David\AppData\Roaming\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -MMD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=10604 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/libsam -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/CMSIS/Include/ -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/Device/ATMEL/ -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\variants\arduino_due_x -IC:\Users\David\OneDrive\Arduino\libraries\MAX5216 -IC:\Users\David\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\libraries\SPI -IC:\Users\David\OneDrive\Arduino\libraries\MAX5216\utility C:\Users\David\OneDrive\Arduino\libraries\MAX5216\MAX5216.cpp -o C:\Users\David\AppData\Local\Temp\build6335026798324731736.tmp\MAX5216\MAX5216.cpp.o
And nothing else happens, never ever.
I have read all I can find online but this I cannot solve, please advise.
Regards
