[SOLVED] My TM1637 didnt functioning on second attempt to turn on relay.
Hi. I am new to this forum, any tips or guidance would be much appreciated. sorry for my bad English I'm Malaysian btw.
I think my problem is not really hard to solve.
I want to build a coin laundry timer. Whenever 50 cents is inserted into the coin acceptor. The relay will turn on for 1 hour and a TM1637 display will show the remaining time.
Right after uploading the code into Arduino. I insert 50 cents into the coin acceptor, and everything works fine, relay turned on and the timer shows the exact remaining time as it supposed to. But on a second try, without restarting or reuploading the code. The timer isn't functioning.
Below is my code. I'm sorry the code is a little bit messy.
#define numberOfSeconds(time) ((time / 1000) % 60)
#define numberOfMinutes(time) (((time / 1000) / 60) % 60)
#include <TM1637Display.h>
#include <elapsedMillis.h>
elapsedMillis timeElapsed;
const uint8_t OFF[] = {0, 0, 0, 0};
const uint8_t PLAY[] = {B01110011, B00111000, B01011111, B01101110};
unsigned long timeLimit = 60000;
unsigned long interval = 60000;
const int relay = 7;
const int coinpin = 2;
const int ledpin = 13;
const int targetcents = 5;
volatile int cents = 0;
int credits = 0;
TM1637Display display(8, 9);
  attachInterrupt(digitalPinToInterrupt(coinpin), coinInterrupt, RISING);
  pinMode(ledpin, OUTPUT);
  pinMode(relay, OUTPUT);
  digitalWrite(relay, HIGH);
  //TIMER SECTION 2
  display.setBrightness(0x0c);
  display.setSegments(PLAY);
  if (cents >= targetcents) {
    credits = credits + 1;
    cents = cents - targetcents;
  else {}
  Serial.print(cents);
  Serial.print(" cents toward current credit and ");
  Serial.print(credits);
  Serial.println(" credit(s) earned so far.");
  if (credits == 1) {
    digitalWrite(relay, LOW);
    unsigned long timeRemaining = timeLimit - millis();
    while (timeElapsed < interval) {
      int seconds = numberOfSeconds(timeRemaining);
      int minutes = numberOfMinutes(timeRemaining);
      display.showNumberDecEx(seconds, 0, true, 2, 2);
      display.showNumberDecEx(minutes, 0x80 >> 3, true, 2, 0);
    credits = credits - 1;
void coinInterrupt() {
  cents = cents + 1;
void displayText() {
  delay(2000);
But I think the problem is within this line of code.
 if (credits == 1) {
timeElapsed has been declared as a variable of type elapsedMillis, but where is it being reset?
Hello Izuanika
Are you using this library?
If not, please tell us which library you're using.
Regards,
bidouilleelec
Hi bidouileelec
bidouilleelec:
Hello Izuanika
Home · pfeerick/elapsedMillis Wiki · GitHub
Regards,
bidouilleelec
Yes im using the library you mentioned above.
Hi DKWatson
DKWatson:
Thank you. My mistake, I did not read the guideline for elapsedMillis carefully before using the library
I should put timeElapsed = 0; somewhere after timer loop function.
Case closed.
