<SOLVED>need assistance with logic for sensor state change counting
I am trying to count every time the photo and motion sensors change state independently to activate the lights and display it on the 16x2 lcd. I have the display formatted and the sensors do what is expected but the counters run wild. I have included all of the logic that i have cobbled together so far in the code below. i have 2 functions setup. 1 for counting and one for activating the lights. please help with the logic. Thank you.
const int sensorDark = 500;
const int sensorMotion = 500;
// the photocell voltage divider pin
int photocellPin = A0;
int motionPin = A1;
// the LED pin
int LEDPin = 8;
// Global Variables
int motion = 0;
int photo = 0;
int analogValueP;
int LoopCurrentP;
int LoopPreviousP;
int analogValueM;
int LoopCurrentM;
int LoopPreviousM;
    // initialize the LED pin as output
    pinMode(LEDPin, OUTPUT);
    // set up serial
    // set up the LCD's number of columns and rows:
    lcd.begin(16, 2);
    // read our photocell
    analogValueP = analogRead(photocellPin);
    analogValueM = analogRead(motionPin);
    // Turn on the LED
    if ((analogValueP < sensorDark)&&(analogValueM > sensorMotion)){
          digitalWrite(LEDPin, HIGH);
          LoopCurrentP = 1;
          LoopCurrentM = 1;
    // Otherwise turn the LED off
      if ((analogValueP > sensorDark)||(analogValueM < sensorMotion)){
          digitalWrite(LEDPin, LOW);
          LoopCurrentP = 0;
          LoopCurrentM = 0;
    // wait 1ms for better quality sensor readings
    delay(1);
    PrintInfo();
    TickerCount();
void TickerCount()
    // Increment counter for Photo Cell by 1
    if (LoopCurrentP == LoopPreviousP){
      LoopPreviousP = 0;
      photo++;
    else {
      LoopPreviousP = 1;
    // Increment counter for Motion Sensor by 1
    if  (LoopCurrentM == LoopPreviousM){
      LoopPreviousM = 0;
      motion++;
    else {
      LoopPreviousM = 1;
output of variable photo
2101
2102
2103
2104
2105
2106
2107
2108
2109
2110
2111
2112
2113
2114
2115
2116
2117
2118
2119
2120
2121
2122
2123
2124
2125
2126
2127
2128
2129
2130
2131
2132
2133
2134
2135
2136
2137
2138
2139
2140
2141
2142
2143
2144
Figured it out. Posted the code below.
 * Automatically turns on an LED when it gets dark and motion is detected.
 * It will also count how many times the individual sensors change state
 * Author: Joseph Gzesh & Elijah Gzesh
// include the library
#include <LiquidCrystal.h>
// all of our LCD pins
const int rs = 12, e = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(rs, e, d4, d5, d6, d7);
/* A constant that describes when its dark enough to
* light the LED. A value close to 600 will light the led
* with less darkness.
/* A constant that describes when a motion occurs near by to
* light the LED. A value close to 300 will light the led
* with more motion.
// the motion voltage pin
int motionPin = A1;
// the LED pin
int LEDPin = 8;
// Global Variables
int motion = 0;
int photo = 0;
int analogValueP;
int LoopCurrentP = 0;
int LoopPreviousP = 0;
int analogValueM;
int LoopCurrentM = 0;
int LoopPreviousM = 0;
    lcd.begin(16, 2);
    // read our motion sensor
    // The higher the analogValueP reading is the darker it is.
    // If its at least as dark as our constant "sensorDark"
    // and the lower the analogValueM reading is the more motion being detected
    // If its at least as high as our constant "sensorMotion"
    // light the led
    else{
    if (analogValueP < sensorDark){
      LoopCurrentP = 1;
    }else{
      LoopCurrentP = 0;
    if (analogValueM > sensorMotion){
      LoopCurrentM = 1;
    }else{
      LoopCurrentM = 0;
    delay(1);
    PrintInfo();
    TickerCount();
    LoopPreviousM = LoopCurrentM;
    LoopPreviousP = LoopCurrentP;
void TickerCount()
    if  (LoopCurrentM != LoopPreviousM){
        motion++;
    // Increment counter for Photo Sensor by 1
    if  (LoopCurrentP != LoopPreviousP){
        photo++;
void PrintInfo()
  // This prints on the first line of the 16x2 display
  lcd.setCursor(0, 0);
    lcd.print("P: ");
    lcd.print(photo);
  lcd.setCursor(8, 0);
    lcd.print("M: ");
    lcd.print(motion);
  lcd.setCursor(0, 1);
    lcd.print(millis() / 1000);
Karma for code tags and kudos for diligence.
Editing your thread title to include something like: [SOLVED] may help someone in the future.
