[SOLVED] Need help with Max7219 and LedControl library
Just had to update this. I was able to add another digit and create a little routine that counts down from 99 to 0 and repeats the cycle. Now that I've done 2 digits, I should hopefully be able to complete the remaining 6. Here's a video link and the code.
By the way - the LedControl library makes this so much easier.
Quick video:
The code:
#include "LedControl.h" //  need the library
LedControl lc=LedControl(12,11,10,1); // lc is our object
// pin 12 is connected to the MAX7219 pin 1
// pin 11 is connected to the CLK pin 13
// pin 10 is connected to LOAD pin 12
// 1 as we are only using 1 MAX7219
  // the zero refers to the MAX7219 number, it is zero for 1 chip
  lc.shutdown(0,false);// turn off power saving, enables display
  lc.setIntensity(0,8);// sets brightness (0~15 possible values)
  lc.clearDisplay(0);// clear screen
    //This code should count down from 99 displaying the numbers on the two digits
    static int theNumber = 99;
    int digitOne, digitTwo;
    if (theNumber < 0)
      theNumber = 99;
    if (theNumber > 9)
      float result = theNumber / 10;  //s/b 4.2 resulting in 4
      digitOne = result;
      digitTwo = theNumber % 10;  //this gets the remainder of 42/10 or 2
      digitOne = 0;
      digitTwo = theNumber;
    lc.setDigit(0,0,digitOne,false);
    lc.setDigit(0,1,digitTwo,false);
    delay(100);
    theNumber --;
