Hello. I am new to coding and this forum. I do it for around two months at the workshop. I am a trainee. My trainer gave me a code and said that I should find the mistake. The created symbol should go right. In the loop() function I can change "arrayRotateRight();" to either left or right. When it says "arrayRotateLeft();" the symbol moves to the left, but when I change it to "arrayRotateRight();" it doesn't move and stays at the top-left corner of the screen. In "void arrayRotateRight()" should be the error, but I can't imagine what it should look like to fix my problem. Any sort of help would be appreciated and if possible could you add comments in the code so I can understand it? Thanks.
Btw. A normal 16x2 LCD is used
#include <LiquidCrystal.h>
byte gewicht[8]{ //Gewicht
B00000,
B11111,
B01110,
B11111,
B11111,
B11111,
B11111,
B11111,
LiquidCrystal lcd(12,11,5,4,3,2);
char puffer[16][2];
const int Button = 8; //Anschluss Prototyp
const int LED = 13; //Anschluss Prototyp
const int Speaker =9; //Anschluss Prototyp
pinMode(LED,OUTPUT);
pinMode(Button,INPUT_PULLUP);
lcd.begin(16,2);
lcd.createChar(0, gewicht); //Gewicht
arrayInit();
puffer[0][0]= 0;
arrayToDisplay();
arrayRotateRight();
* Hier kommen die Unterprogramme
void arrayInit(){
for(byte i=0; i<16; i++){
for (byte j=0; j<2; j++){
puffer[i][j] = ' ';
void arrayRotateLeft(){
char temp1, temp2;
temp1 = puffer[0][0];
temp2 = puffer[0][1];
for (byte i=1; i<16; i++){
puffer[i-1][0] = puffer[i][0];
puffer[i-1][1] = puffer[i][1];
puffer[15][0] = temp1;
puffer[15][1] = temp2;
void arrayRotateRight(){
char temp1, temp2;
temp1 = puffer[15][0];
temp2 = puffer[15][1];
for (byte i=14; i>=0; i--){
puffer[i][0] = puffer[i+1][0];
puffer[i][1] = puffer[i+1][1];
puffer[0][0] = temp1;
puffer[0][1] = temp2;
void arrayToDisplay(){
lcd.setCursor (0,0);
for (int i=0; i<16; i++){
lcd.write (puffer[i][0]);
lcd.setCursor (0,1);
lcd.write (puffer[i][1]);
sample.ino (1.62 KB)
Robin2
April 7, 2020, 2:55pm
2
As this is a programming problem I have suggested to the Moderator to move it to the Programming section.
It is much easier for people to help when you include short programs in your Post so they don't have to download them. Like this
B00000,
B11111,
B01110,
B11111,
B11111,
B11111,
B11111,
B11111,
char puffer[16][2];
const int Taster = 8; //Anschluss Prototyp
pinMode(Taster,INPUT_PULLUP);
lcd.begin(16,2);
arrayInit();
puffer[0][0]= 0;
arrayToDisplay();
arrayRotateRight();
void arrayInit(){
puffer[i][j] = ' ';
char temp1, temp2;
char temp1, temp2;
for (byte i=14; i>0; i++){
See How to use the forum
...R
Here is your problem (or one of them):
Change i++ to i--
You have narrowed the problem down to the arrayRotateRight() function, try the for loop by hand with a few values of i and see what it is doing.
char temp1, temp2;
Robin2:
Okay Thanks. I have changed it now. I also try to follow the steps from the link you send. Again, new here.
ToddL1962:
Change i++ to i--
I tried but ut didn't work. I also added "=" between ">" and "0" but it still doesn't move to the right, stays in the top-left corner. I am lost and there can't be anything wrong with how it is build because in the "left" function it works.
You need to post your code
TheMemberFormerlyKnownAsAWOL:
You can't see it? I thought I have post it after Robin2 mentioned it.
But here you go:
B00000,
B11111,
B01110,
B11111,
B11111,
B11111,
B11111,
B11111,
char puffer[16][2];
lcd.begin(16,2);
arrayInit();
puffer[0][0]= 0;
arrayToDisplay();
arrayRotateRight();
void arrayInit(){
puffer[i][j] = ' ';
char temp1, temp2;
char temp1, temp2;
Robin2
April 8, 2020, 8:25am
9
codenewb:
The request in Reply #6 was to post the latest version of the program with the changes that you say (in Reply #5 ) that you tried but which did not solve the problem.
Is the code in Reply #7 the latest version?
...R
Robin2:
...R
Yep. The last code is the newest.
codenewb:
Have you looked at the "left" function, to understand what it is doing and how it works? The if statement in the "right" function is incorrect, but that does not mean it is the only problem.
david_2018:
Are we looking at the same code?
Okay guys, I got the solution.
Befor:
char temp1, temp2;
After:
char temp1, temp2;
for (int i=14; i>=0; i--){
puffer[i+1][0] = puffer[i][0];
puffer[i+1][1] = puffer[i][1];
I changed the datatype "byte" to "int" int the for function. I also changed
to
That was the error. Thank you for trying to help. How can I close this thread or mark it as solved or something like that?
Robin2
April 8, 2020, 9:39am
14
codenewb:
There is no requirement to do anything, but, if you wish, you can edit your Original Post and add the word [SOLVED] to the title.
...R
It can be done with a data type of byte, just have to avoid the test for >= 0 because byte is an unsigned integer, so can never be < 0.
for (byte i=15; i>0; i--){
puffer[i][0] = puffer[i-1][0];
puffer[i][1] = puffer[i-1][1];
