[Solved] No such file or directory
Hello,
Within the past few days, I am receiving a "No such file or directory" error on compilation for particular files, although they are clearly included in the sketch. Deleting them and re-importing them into the sketch fixes the problem temporarily. If I log back into Web Editor and try to compile again, I get the same error, although the files are clearly labeled in tabs in the sketch.
The sketch compiled just fine last week.
Any help would be greatly appreciated.
Thanks!
Joshua
@jdreichard
Have you tried any of the steps mentioned here and elsewhere in this section regarding clean up of cache etc.
Could you also read this and then provide some additional info please.
Hi @jdreichard,
thanks for you report, there was actually an issue, we published a fix, can you tell us if it still happens?
