I have a ESP8266 with a 5110 display running U8g2
The display is too dim to read.
when run from a NANO, the same sketch, the display is bold.
Both are run from 3 volt pins, neither uses the back-light.
the contrast statement has no effect and I have read that some of these displays do not have variable contrast. assuming it is a feature in the actual driver chip.
It may be worth looking further into this...
u8g2 has one contrast option from 0 to 255
changing values in contrast has no effect.
I have come across sites where they mention that contrast may not be accessible due to circuit board design.
thinking I should have started this thread in the displays section.
I have not tried any other display libraries, u8g nor adafruit
question was asked: what voltages ?
connected a jumper to pin A0 on the nano
connected grounds
read voltage of the two boards
power to each was from USB on different ports
dave-in-nj:
connected grounds
Still not clear where the VCC for the 5110 is comming from, you have said so far;
'tossed in A0 on the nano, connected grounds'.
'connected a jumper to pin A0 on the nano'
UPDATE :
it was a hardware problem. I found that when I removed the plastic screen protector, the screen was scratched and dirty around the edges. it was a pull from some device. they seller noted that one might have to squeeze the screen to get better contact.
