[SOLVED] NOOB order query
Hi, I am pretty much a noob so please be gentle with me!
I am trying to set up a camera slider that moves a camera (Stepper Motor X), pans (Stepper Motor Y) and then focuses and releases the shutter. (Foucus has to be high whilst shutter is on to take a picture)
I am currently using an Uno CNC shield to help with the stepper motor control
I am currently struggling to get everything going in the correct order and I can't figure out why.
Start again.
The code I currently have is below where am I going so wrong?
The sequence I would like would be
Stepper X 200 Steps
Stepper Y 20 Steps
Focus on for 4 secs before
Shutter on 1/2 sec
Shutter off
Focus off
Loop to start. Eventually I will add a microswitch to stop movement at the end of the track but I'll worry about that later!
const int StepX = 2;
const int DirX = 5;
const int StepY = 3;
const int DirY = 6;
const int Shutter = 4;
const int Focus = 7;
  pinMode(StepX,OUTPUT);
  pinMode(DirX,OUTPUT);
  pinMode(StepY,OUTPUT);
  pinMode(DirY,OUTPUT);
  pinMode(Shutter,OUTPUT);
  pinMode(Focus,OUTPUT);
void SliderMotor ();
  digitalWrite(DirX, HIGH);
 for(int x = 0; x<200; x++) { // loop for 200 steps
  digitalWrite(StepX,HIGH);
  delayMicroseconds(500);
  digitalWrite(StepX,LOW);
  delay(3000);
 // delay for 3 second
void PanMotor ();
  digitalWrite(DirY, LOW);
 for(int x = 0; x<20; x++) { // loop for 20 steps
  digitalWrite(StepY,HIGH);
  digitalWrite(StepY,LOW);
  delay(3000);// delay for 3 second
void Shutter();
  digitalWrite(Focus,HIGH);//focus camera on
  delayMicroseconds(4000);
  digitalWrite(Shutter, HIGH);//take picture
  digitalWrite(Shutter,LOW);
  delayMicroseconds(1000);
  digitalWrite(Focus,LOW);
Welcome to the forum
    for (int x = 0; x < 200; x++) // loop for 200 steps
To start with you have a function definition inside a function
const int DirX = 5;
const int DirY = 6;
  pinMode(StepX, OUTPUT);
  pinMode(DirX, OUTPUT);
  pinMode(StepY, OUTPUT);
  pinMode(DirY, OUTPUT);
  pinMode(Shutter, OUTPUT);
  pinMode(Focus, OUTPUT);
//  SlideMotor();
//  PanMotor();
//  Shutter();
void SliderMotor ()
    digitalWrite(StepX, HIGH);
    digitalWrite(StepX, LOW);
    delay(3000); // delay for 3 second
void PanMotor ()
  for (int x = 0; x < 20; x++)   // loop for 20 steps
    digitalWrite(StepY, HIGH);
    digitalWrite(StepY, LOW);
void Shutter()
  digitalWrite(Focus, HIGH); //focus camera on
  digitalWrite(Shutter, LOW);
  digitalWrite(Focus, LOW);
No user functions are called in setup() or loop() so the code does nothing.
Thanks.
This was a last ditch attempt. Maybe need to go back to arduino school.
What are you trying to do with this line ?
Are you trying to call the function or to define the function ?
I've tidied it up closer to where I started.
Is this better? Its still not sequencing properly but is less complicated I think
const int DirX = 5;
const int DirY = 6;
 digitalWrite(DirX, HIGH); // set direction, HIGH for clockwise, LOW for anticlockwise
 digitalWrite(DirY, HIGH);
delay(1000); // delay for 1 second
delay(1000);{ // delay for 1 second
DelayMicrroseconds is fine for steppers, but did you really mean to use them for your focus and shutter delays?
It compiles so that is a big advance
Whether it does what you want is another matter
No, should I just use delay?
Yes.
Might just be the problem! Mili vs Micro Doh! Thanks will try that when I get home!
Sorted thanks to the delay issue! Thanks everyone! I’ll be back asking for help with inputs to control the slider motor movement and stop switches next! Thank you all!
