I'm brand new to programming so there may well be some obvious errors in my code, but its baffling me.
I have tried to play around with an example which turns one LED on then, turns on the next one and turns off the former (one LED will look like it is scrolling along the line).
my goal is to have the LEDs scroll in (as before) and 'fill up' (stay on), then scroll off again to 'empty' (turn off).
the code seems to run fine for a few loops but on the 'fill' function the 5th loop LEDs 1,2,4 and 5 turn on before the 'empty' function starts. Then the whole code seems to stop after the 'empty' on the 7th loop when LEDs 1,2 and 3 stay on.
I added the delays into the void loop() to check if all the LEDs were getting reset properly, and strangly the code breaks even sooner (the start of the 4th loop) if the delays are taken out.
any help would be appreciated, and feel free to let me know if there is a better way to write the code.
Thanks
int ledpins[] = {2,3,4,5,6,7,8,9}; //array to hold led pin #s
//i.e. ledpin #0 is pin 2 on board and so on
void setup ()
for(int i = 0; i < 8; i++){
pinMode(ledpins[i],OUTPUT);
fill(); //leds 'move' left to right (low to high pin #s)
// and stay on right to left (one led per loop)
delay (1000); //added to troubleshoot
empty(); //leds 'move' left to right, starting one lower each time)
void fill(){
int delayTime = 100;
for (int x = 7; x >= 0; x--){ //decrease x per loop
//to lower # of leds activated per loop
//so once filled the leds stay on
for (int i = 0; i <= x; i++){
int offled = i - 1;
digitalWrite (ledpins[i], HIGH);
digitalWrite (ledpins[offled], LOW);
delay(delayTime);
void empty(){
//works its way back down the row
for (int i = x; i <= 7; i++){
int onled = i + 1;
digitalWrite (ledpins[i], LOW);
digitalWrite (ledpins[onled], HIGH);
delay(delayTime);
since i dont want to turn off LED 7 when 1 turns on i deleted the 'if' part and assumed the code would ignore the reference to pin -1.
any advice on how to fix this? i just tried adding if (i == 0){} in the hopes this would mean "if i = 0, do nothing" but the code ran exactly the same.
void setup ()
void fill(){
int offled = (i==0) ? 0: (i - 1);
delay(delayTime);
void empty(){
int onled = (i==7) ? 7 : (i + 1);
delay(delayTime);
This should fix your "pointer" on and off problem. But I think that the last and first LED won't be visible. So that's not the solution.
But why not:
void fill(){
int offled = i - 1;
if (offled >0)
delay(delayTime);
void empty(){
int onled = i + 1;
if (onled <7)
delay(delayTime);
I added your suggestions and the code ran great, the only issue was that the 1st led stayed on during the whole 'fill' function, and the 8th one stays off during the 'empty' function.
I changed the if statements to look at 'i' instead of 'offled' and 'onled' which fixed it.
for reference:
the full code below displays the led pattern that lloyddean wrote above.
void setup ()
void fill(){
int offled = i - 1;
if (i >0)
delay(delayTime);
void empty(){
int onled = i + 1;
if (i <7)
delay(delayTime);
for reference:
void setup ()
void fill(){
int offled = i - 1;
if (i >0)
delay(delayTime);
void empty(){
int onled = i + 1;
if (i <7)
delay(delayTime);
