On the FTDI device its called RTS so disconnect that and use the reset switch that came with the kit?
DO I need the Caps like they show on the diagram for the crystal? That would not be the reason for the sync error would it?
When do you reset manually before and after the successful upload of the sketch?
Actually when I was using the manual switch with the Cap and Resistor I still got the sync error
