[Solved] NRF24L01, Receiving and displaying multiple integers correctly
I have two NRF24L01 hooked up to two Arduinos. Arduino 1 first sends a 1 to Arduino 2 and then Arduino 2 sends back 4 integers in a structure I call payload. The four numbers I send are:
x = 200
y = 300
z = 99
a = 10
When I receive the numbers and try to display the structure through the serial monitor on Arduino 1, I get the numbers:
x = 200
y = 300
z = 0
a = 0
In addition, if i try sending those four numbers using an array instead of a structure I get the numbers:
x = 200
y = 300
z = 16138
a = 16358
Below is the code I am using.
Transmitter:
#include <SPI.h>
#include "RF24.h"
int msg[1] = {1};
struct Payload
   int x;
   int y;
   int z;
   int a;
} payload;
/****************** User Config ***************************/
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(10,9);
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
  Serial.println(F("RF24 Transmitter"));
  struct Payload payload;
  radio.begin();
  radio.setPALevel(RF24_PA_LOW);
  radio.openWritingPipe(addresses[1]);
  radio.openReadingPipe(1,addresses[0]);
  // Start the radio listening for data
  radio.startListening();
    radio.stopListening();                                    // First, stop listening so we can talk.
    Serial.println(F("Now sending"));
    if (!radio.write( &msg, sizeof(unsigned long) )){
      Serial.println(F("failed"));
    radio.startListening();                                    // Now, continue listening
    unsigned long started_waiting_at = micros();               // Set up a timeout period, get the current microseconds
    boolean timeout = false;                                   // Set up a variable to indicate if a response was received or not
    while ( ! radio.available() ){                             // While nothing is received
      if (micros() - started_waiting_at > 200000 ){            // If waited longer than 200ms, indicate timeout and exit while loop
          timeout = true;
    if ( timeout ){                                             // Describe the results
        Serial.println(F("Failed, response timed out."));
    }else{
        radio.read( &payload, sizeof(unsigned long) ); // read what is sent back
        // display what is recieved
        Serial.print(F("Sent "));
        Serial.print(msg[0]);
        Serial.print(F(", Got response: x: "));
        Serial.print(payload.x);
        Serial.print(F(" y: "));
        Serial.print(payload.y);
        Serial.print(F(" z: "));
        Serial.print(payload.z);
        Serial.print(F(" a: "));
        Serial.println(payload.a);
    // Try again 1s later
and Receiver
#include <SPI.h>
#include "RF24.h"
struct Payload
   int x = 200;
   int y = 300;
   int z = 99;
   int a = 10;
} payload;
RF24 radio(10,9);
  Serial.println(F("RF24 Reciever"));
  Serial.println(sizeof(unsigned long));
  radio.begin();
  radio.openWritingPipe(addresses[0]);
  radio.openReadingPipe(1,addresses[1]);
    unsigned int rec;
    if( radio.available()){
        // Variable for the received timestamp
      while (radio.available()) {                                   // While there is data ready
        radio.read( &rec, sizeof(unsigned long) );             // Get the payload
      radio.write( &payload, sizeof(unsigned long) );              // Send the final one back.
      Serial.print(F("Received "));
      Serial.print(rec);  // Now, resume listening so we catch the next packets.
      Serial.print(F(", Sent response x: "));
} // Loop
Any idea what I am doing incorrectly?
Life will be much easier if you send the complete struct - something like this
radio.write( &payload, sizeof(payload) )
and receive if with
radio.read( &payload, sizeof(payload) );
...R
Simple nRF24L01+ Tutorial
You are throwing away packets if there ever happen to be more than one available, why?
What a silly mistake by me. All fixed, thank you!
