hi guys
i am trying to store each sent packet from a transmitter to a receiver in a separate array
for example
arr1 for packet 1
arr2 for packet 2
how can this be made?
thanks in advance for ur help
hi guys
for example
arr1 for packet 1
arr2 for packet 2
Do a memcpy() from your dataReceived to the individual array where you want to store it.
gfvalvo:
thank u for ur reply
but i did not mean this
in the transmitter side i send a packet fully loaded which the receiver receives it successfully ,then i try to send another packet but the receiver can not receive it and receive the first element of the fully loaded packet once again
is there an example or guide line for what should be made?
these are the sketches if u r interested to know the case exactly
Tx
#include "sha256.h"
#include <Arduino.h>
#include "./printf.h"
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define CE_PIN 9
#define CSN_PIN 10
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// NOTE: the "LL" at the end of the constant is "LongLong" type
// These are the IDs of each of the slaves
const uint64_t slaveID = 0xE8E8F0F0E1L ;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
int txVal = 0;
byte ackMessg[6];
byte ackMessgLen = 4;
uint8_t* hash;
uint8_t copy[32];
void printHash(uint8_t* hash) {
int i;
for (i=0; i<32; i++) {
Serial.print("0123456789abcdef"[hash[i]>>4]);
Serial.print("0123456789abcdef"[hash[i]&0xf]);
copy[i]=hash[i];
printf_begin();
uint32_t a;
unsigned long ms;
sensors.begin();
radio.begin();
radio.setDataRate( RF24_2MBPS );
radio.enableAckPayload();
radio.setRetries(3,5); // delay, count
// SHA tests
/// Serial.println("Test: FIPS 180-2 B.1");
/// Serial.println("Expect:ba7816bf8f01cfea414140de5dae2223b00361a396177a9cb410ff61f20015ad");
/// Serial.print("Result:");
ms = micros();
Sha256.init();
Sha256.print("abc");
printHash(Sha256.result());
for(int x=0;x<32;x++)
{ //Serial.print(copy[x]);
// Serial.print(" ");
// Serial.println();
//Serial.print(" Hash took : ");
// Serial.print((micros() - ms));
// Serial.println(" micros");
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
radio.openWritingPipe(slaveID);
bool rslt,rsltt;
rslt = radio.write( copy, 32 );
if ( radio.isAckPayloadAvailable() ) {
radio.read(ackMessg,ackMessgLen);
Serial.print("Acknowledge received: ");
Serial.print(ackMessg[0]);
Serial.print(" ");
Serial.println(ackMessg[1]);
if(ackMessg[1]==23)
{sensors.requestTemperatures();
Serial.print("Temperature is: ");
byte x=sensors.getTempCByIndex(0);
radio.write( x, sizeof(x) );
Serial.print(x);
prevMillis = millis();
Rx
int temperature ;
unsigned long startTimer = millis();
if ( radio.available() ) {
byte temperature[1] ;
radio.read( (char*)dataReceived, sizeof(dataReceived) );
Serial.println(startTimer);
for (int x = 0; x <32; x++) {
//if (dataReceived[x] < 16) {
// Serial.write('0'); }
Serial.print(dataReceived[x]);
Serial.print(" ");
i = 0;
do
bMatch = true;
for( j=0; j<NUM_ELEMENTS; j++ )
if( dataReceived[j] != buffers[i][j] )
bMatch = false;
if( !bMatch )
i++;
while( i < NUM_COMPARES && !bMatch );
if( bMatch )
{ radio.writeAckPayload(1, ackData, sizeof(ackData));
radio.read(temperature, sizeof(temperature));
Serial.println("temperature is ");
Serial.print(temperature[0]);
Serial.println( );
ackData[0] += valChange; // this just increments so you can see that new data is being sent
Serial.print( "Match found at buffer[" );
Serial.print(i);
Serial.println( "]" );
Serial.println( "No match found." );
output at receiver
186 120 22 191 143 1 207 234 65 65 64 222 93 174 34 35 176 3 97 163 150 23 122 156 180 16 255 97 242 0 21 173
temperature is
173
Match found at buffer[0]
which shows that temperature value has not been received
i discovered the error
i did not put the rado.write line in the write place
these are my working codes
Rx
#include <SPI.h>
//~ #include <TMRh20nRF24L01.h>
//~ #include <TMRh20RF24.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
#define NUM_COMPARES 2
#define NUM_ELEMENTS 32
const uint64_t deviceID = 0xE8E8F0F0E1LL; // Define the ID for this slave
uint8_t buffers[NUM_COMPARES][NUM_ELEMENTS] ={ {186, 120, 22 ,191, 143 ,1 ,207 ,234 ,65 ,65 ,64, 222, 93 ,174 ,34, 35, 176, 3 ,97 ,163 ,150, 23, 122 ,156, 180 ,16 ,255 ,97, 242, 0, 21 ,173},
{86, 120, 22 ,191, 143 ,1 ,207 ,234 ,65 ,65 ,64, 222, 93 ,174 ,34, 35, 176, 3 ,97 ,163 ,150, 23, 122 ,156, 180 ,16 ,255 ,97, 242, 0, 21 ,173}};
int valChange = 1;
bool bMatch;
int i, j;
uint8_t dataReceived[32];
byte ackData[2] = {12,23};
byte tempReceived[4];
Serial.println("Starting");
radio.begin();
radio.openReadingPipe(1,deviceID);
radio.startListening();
int temperature ;
Serial.print(" ");
i = 0;
do
bMatch = true;
bMatch = false;
if( !bMatch )
i++;
if( bMatch )
Serial.println( );
Serial.print(i);
Tx
#include "sha256.h"
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
int txVal = 0;
byte ackMessg[6];
uint8_t* hash;
uint8_t copy[32];
int i;
copy[i]=hash[i];
printf_begin();
uint32_t a;
unsigned long ms;
sensors.begin();
radio.begin();
// SHA tests
ms = micros();
Sha256.init();
bool rslt,rsltt;
Serial.print(" ");
if(ackMessg[1]==23)
{//sensors.requestTemperatures();
radio.write( &x, sizeof(x) );
Serial.print(x);
