There's another way: In C++, you can specify the size of an array as function parameter.
For example, a function that takes a float array with 3 elements as a parameter:
void fn(float (&array)[3]) {
You could use it as follows:
float array1[] = {1, 2.5, 3.1};
fn(array1);
However, if you try an array with a different length, the compiler will complain:
float array1[] = {1, 2.5, 3.1, 4.6};
fn(array1);
error: invalid initialization of reference of type 'float (&)[3]' from expression of type 'float [4]'
fn(array1);
note: in passing argument 1 of 'void fn(float (&)[3])'
You could solve this by overloading the function (i.e. creating a version of the function for every type of parameter you need, so a new function for every length):
void fn(float (&array)[1]) {
void fn(float (&array)[2]) {
void fn(float (&array)[4]) {
// etc ...
As you can see, it would be a pain to write them all out manually. Luckily, C++ has something called function templates:
template <size_t N> void fn(float (&array)[N]) {
This will define a family of functions, all with a different length N for 'array'. The compiler will automatically overload the function with any length N needed in your program.
A more extensive example:
template <size_t N> void printArray(float (&arr)[N]) {
Serial.print("Array size: ");
Serial.println(N);
for (size_t i = 0; i < N; i++) {
Serial.print('\t');
Serial.print(arr[i]);
while (!Serial);
printArray(array1);
void loop() {}
This will print:
Array size: 3
1.00 2.50 3.10
Note that this will only work if the length of the array is fixed, and known at compile time.
For example, this won't work:
while (!Serial);
printArray(array1);
size_t length = random(1, 10);
float* array2 = new float[length];
for (size_t i = 0; i < length; i++) {
array2[i] = 1.0 / (i + 1);
printArray(array2);
delete[] array2;
This is easy to solve, though:
printArray(arr, N);
void printArray(float* arr, size_t length) {
Serial.println(length);
Serial.print('\t');
while (!Serial);
printArray(array1);
printArray(array2, length);
delete[] array2;
void loop() {}
Note how the template function from before is now just a wrapper for the actual function.
Pieter
