[SOLVED] OLED 256x64 PCB How to ?
Hi guys,
This is my first post on this great community ! I hope everything will be fine ! :wink:
I recently ordered and received a OLED 256x64 display.
Model : ER-OLEDM028-1
(The documentation can be found Here )
My problem is simple. How can i connect this PCB to my Arduino UNO board. :astonished:
I found a lots of thread to how to do but they all talking about differents displays.
Anything about my model.
The references are differents and when i try connect the display to the arduino board and load a code, the screen stay black .
This is my cable plugged configuration :
OLED-------Arduino
D0-----------10
D1-----------9
RST----------13
DC-----------11
VCC----------5V
GND----------GND
This is the code i used : here and and
(I mention i tried with a lot's of code example )
Tried whith other code without success... :confused:
Please, if someone has used an oled display like this one, can he help me ?
Thank for reading guys.
This is my montage :
The plate is juste used to prevent connexion between cables.
All is on the arduino uno. the Usb connector is unplugged for the photo.
Im not an expert on this, and i havent read the topic, but this guy was having the same problem as you
The data sheet you provided shows that the controller is a ssd1322
http://forum.arduino.cc/index.php?topic=255465.0
I followed this post. Tried to unsolder the resistor from position R19 and resolder it on position R18.
Place the same parameters .
Nothing ....
Solved !
the problem is due to the extension flat cable.
For an unknown reason, i can't extend the 50 pin flat cable from the screen PCB to the display.
But i solved my problem using this thread :
