[solved] passing #define and how can it work elsewhere
I have read a lot about defines in an .ino and using them within a libary. Using VS2017 w Visual Micro btw. Tried (cutted the non-interesting part):
ino:
#define TEST 1
#include "pass_test.h"
pass_test.h:
#ifndef TEST
#error test not defined!
#endif
Result:
pass_test.h: 14:2: error: #error test not defined!
Some say it works if the ifdef is used within the .h, for me (as you can see) it does not.
On the other hand, I´m using the MySensors-Gateway, and their libary. My code in .ino:
#define MY_NODE_ID 95
#include <MySensors.h>
begin of the MySensors.h:
#ifndef MySensors_h
#define MySensors_h
#ifdef __cplusplus
#include <Arduino.h>
#endif
// general macros
#if !defined(_BV)
#define _BV(x) (1<<(x)) //!< _BV
#endif
#include "MyConfig.h"
and within the MyConfig.h, first use of “MY_NODE_ID” at line 1062.:
#ifndef MY_NODE_ID
#define MY_NODE_ID (AUTO)
#endif
I can confirm that I can set the node id and it is used, or if I do not, it auto assignes one. So the question for me is: how the heck does it work?!? MY_NODE_ID is not used within MySensors.h and can be used within the MyConfig.h, coming from my .ino file.
I have btw tried to call a .h from my first .h, and use it there, same as on the MySensors example - no luck.
MySensors Libary on git: GitHub - mysensors/MySensors at master
Your .ino / .h files worked as expect for me. Compiling for an Uno with Arduino 1.8.5.
gfvalvo:
What the .. thank you very much for your feedback. As long as there is only the .h, and the file is not included anywhere else, it works :smiley:
I have before tried to create another .h and .cpp, and just removed the cpp from the project, which also threw me an error - seems the cpp had some influence, and only using a .h is the key.
Awesome, thanks again!
EVERY file that you want to include 'test_pass.h' into MUSTdefine 'TEST', not just the .ino. This works fine:
.ino file:
#define TEST 1
void setup() {}
void loop() {}
.cpp file:
#define TEST 1
pass_test.h:
#ifndef TEST
#endif
