[SOLVED] pipes supprting auto ack NRF24L01
Nope.
The NRF24L01+ chips work as described in the datasheet.
mestek123:
pipes 2-5 dusn work at all not just receiving ack
Pipes do not receive any acks, they may in a way send some, three of them with ackpayload.
Acks are always and only received via pipe 0 in the sending node.
Robin2:
Post the ****** programs so we can see them - and maybe try them.
...R
it is the same of the original program that i sent in the first post but without SHA256
Whandall:
Nope.
hi Whandall
have u checked the full post ?
there is CaptainJack who was suffering from the same matter and also another guy in the same thread and he said he could solve that problem using a way in addresses of the pipes but he described it in a vague way
i can receive ack via pipes 0,1,5
but the other 3 pipes are not working
  radio.openReadingPipe(5,rAddress[5]);
You have to set pipe 1 to an address that shares the same prefix.
The way you use it, only the lowest byte of your address will will make it to the controller.
The upper 4 bytes will come from the pipe 1 address that happens to be in the chip.
It’s all in the datasheet.
kindly check this
mestek123:
I think he had a misunderstanding which part of the address in ASCII is the lowest byte.
"1Node" "2Node" "3Node" work,
"Node1" "Node2" "Node3" don't.
Whandall:
i will try ur way and update u immediately
Your problem is different as you are using uint64_t for the addresses (that are wellformed).
Set the f***** pipe 1 address!
mestek123:
Well you keep it to yourself if you want to. I have had enough.
...R
i have tried this addressing
{ '1Node', '2www2', '3xxx3', '4yyy4', '5zzz5' };
it cant work on pipes 1-5 neither on normal transmitting and receiveing nor ack
it works for pipes 0 in but no ack
Read #27 again and change your code accordingly.
Post the latest version of the rx part and - if you made changes to the tx part - that too.
mestek123:
The upper 4 bytes of addresses for pipes 1 to 5 have to be the same, as already mentioned. :confused:
If you want to use one or two pipes, use 0 and 1.
If you need more, use pipes 2 to 5 (with addresses that share the same 4 byte prefix with address 1).
Opening only pipe 2 to 5 listens on an unexpected address. (Prefix 0xC2C2C2C2)
tx code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#include "sha256.h"
This sketch sends a string to a corresponding Arduino
with nrf24 attached.  It appends a specific value
(2 in this case) to the end to signify the end of the
message.
#define WHICH_NODE 1
const uint64_t wAddress[] = { '1Node', '2www2', '2www3', '2www4', '2www5' };
 const uint64_t PTXpipe = wAddress[WHICH_NODE];   // Pulls the address from the above array for this node's pipe
int ackMessg[1];
byte ackMessgLen = 1;
RF24 radio(8,10);
byte arr[32] ;
 uint8_t* hash;
void printHash(uint8_t* hash) {
  for (int i=0; i<32; i++) {
     //(String)hash = (String) ID + (String) hash;
    Serial.print("0123456789abcdef"[hash[i]>>4]);
    Serial.print("0123456789abcdef"[hash[i]&0xf]);
void setup(void)
  radio.begin();
  radio.setDataRate( RF24_250KBPS );
  radio.setChannel(108);
  //radio.setPALevel(RF24_PA_MAX);
  radio.enableAckPayload();
 // radio.setRetries(3,5); // delay, count
  radio.openWritingPipe(PTXpipe);
//  radio.stopListening();
  byte arr[32] ;
  char xx[21];
String str ="12345678901234567890";
str.toCharArray(xx, 21);
Sha256.initHmac((uint8_t*)xx,21);
//Serial.println(xx);
  Sha256.print("node 1");
 // delay(10);
 hash=Sha256.resultHmac();
for( int j=0;j<32;j++)
{arr[j]=hash[j];
 //Serial.print(arr[j],HEX);
 // delay(10);
 byte arr1[33];
   memcpy( arr1, arr ,32);
    //delay(4);
//arr[32]='\0';
//Serial.println();
 //byte arr1[33]="12345678901234567890123456789012";
bool rslt;
rslt=radio.write(arr,sizeof(arr));
if ( radio.isAckPayloadAvailable() ) {
 radio.read(ackMessg,ackMessgLen);
 Serial.print("Acknowledge received: ");
 Serial.println(ackMessg[0]);
//Serial.println(arr1);
//radio.powerDown();
 // delay(100);
//radio.powerUp();
rx
#include <RF24.h>
#include <SPI.h>
This sketch receives strings from sending unit via nrf24
and prints them out via serial.  The sketch waits until
it receives a specific value (2 in this case), then it
prints the complete message and clears the message buffer.
byte pipeNum = 0;
int ackData[1] = {5};
byte ackLen = 1;
RF24 radio(8,10);
 const uint64_t rAddress[] =  { '1Node', '2www2', '2www3', '2www4', '2www5' };
byte theMessage[32] = "";
void setup(void){
  radio.begin();
  radio.openReadingPipe(1,rAddress[1]);
  radio.startListening();
void loop(void)
  while (radio.available(&pipeNum))
      radio.read( theMessage , 32 );
      Serial.print("received : ");
      for(int x=0;x<32;x++)
      Serial.print(theMessage[x],HEX);
      Serial.print(" from ");
      Serial.print(pipeNum);
      radio.writeAckPayload(1, ackData, ackLen);
      //radio.writeAckPayload(2, ackData, ackLen);
     /* if(strcmp(theMessage,"12345678901234567890123456789012")==0)
      {//Serial.println("h");
now it works on pipe 1 only without ack :confused:
If you want to use more than 2 pipes your addresses are crap.
The mixture of uint64_t and ultra long character constants are crap too.
Try something like
const char* rAddress[] =  { "1Node", "2Node", "3Node", "4Node", "5Node" };
I get tired repeating the same stuff over and over.
Whandall:
Try something like
SO SORRY whandall
i will try the suggested addressing and update u
thank u very much for ur great help and ur patience
For a 5 pipe rx-setup you could use
  for (byte i = 0; i<5; i++) {
    radio.openReadingPipe(i+1, rAddress[i]);
whhen i used this on my rx code i get that error
call of overloaded ‘openReadingPipe(int, const char*&)’ is ambiguous
:sob:
and when i used ur part
i got this error :
Snippets are us?
Post the complete changed code!
const byte* rAddress[] =  { "1Node", "2Node", "3Node", "4Node", "5Node" };
should work.
