I'm actually a bit stuck. I need to have a pointer storing an instance of a derived class, but I can't figure out how to do so. Here some code followed by the error message which might help:
#include "RootClass.h"
RootClass::RootClass() {
currentValue = 0;
valueCount = 4; // some default value
Derived.h
#ifndef DERIVED_H
#define DERIVED_H
#include <WProgram.h>
class Derived : public RootClass {
public:
Derived();
#endif
Derived.cpp
#include "Derived.h"
Derived::Derived() : RootClass::RootClass() {
currentValue = 0;
valueCount = 5; // will overwrite the default value (actually works)
sample.ino
Derived a;
Derived b;
RootClass* current; // this is supposed to point to an instance of Derived, changing while the program is running
Derived a();
Derived b();
current = &a; // FAILS: cannot convert 'Derived (*)()' to 'RootClass*' in assignment
What am I missing here?
EDIT:
Corrected name of constructor of Derived class.
Added [solved] to subject.
Thank you very much! That already helped a lot! Now I've got it working with this code:
Derived a;
Derived b;
Derived a;
Derived b;
current = &a;
Serial.println(String(current->valueCount));
Two questions:
As my constructors might need to have some parameters later on, how am I going to pass them (since I need to omit the '()')?
Why can't I set the pointer in the setup-routine (where it might be well placed)?
Because the thing you are pointing to is a local variable that goes away (and gets deleted) when it goes out of scope. Then, you are left with a pointer that does not have the behavior you expect, since the place where ti points to no longer contains an instance of the class that you expect it to have.
Ah, now I understand! I've distinguished between the declaration and the construction - which was not correct. It works when I declare AND construct (in one step) the objects globally:
But doesn't prove anything. If you changed the valueCount field of a and b (by passing a value to the constructor or in setup), and saw that current->valueCount did indeed print differently as you change which object you point to, then you would have proven something.
Don't make me come over there and slap you. There is absolutely no need to convert a char to a String so that the Serial.print() method can extract the char from the String to print it. A monumental waste of resources.
Well, in the actual program (not the example I posted) the proof has been made; but yes, I'm aware that the example is insufficient concerning that.
To justify myself for the waste of resources, I again need to refer to the difference between the example and my actual program, where not a Serial.print is called, but a function which expects a String. I apologize for that
Your function? Rewrite to accept a char *, and get rid of the String class. There is a major bug in the free() function that String uses that can corrupt your program much sooner than was originally thought, considering how many times String calls malloc() and free() (to increase the size of a String by one char).
Uh oh, you were right, I'm running into memory-problems due to the usage of the String-class.
Is that a bug to be fixed in near future or will I need to find a different solution by myself? Where can I get more information about that issue? I could only find some 2 or 3 year old information about something similar (which seems to be fixed meanwhile).
I'm not very used to handling strings using char-arrays or char*s. Is there any good tutorial out there?
Follow that thread. There is a fix available, but I'd still avoid the use of String.
Probably. But, it isn't rocket science. Break the problem down into stages. Collect data, and store it in an array. When that works, move onto to parsing/searching the stored data. Keep in mind the need to reset the array and index at appropriate points.
