Managed to solve the issue. Had to update the WiFi firmware as instructed here. I am attaching the example code bellow for anybody who is interested. The code also passes variables between the sketch layer and the LD program.
#include <WiFi.h>
char ssid[] = "PMC"; // your network SSID (name)
char pass[] = "123456789"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
bool a = false;
int ct=0;
delay(1500);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Access Point Web Server");
Serial.print("Creating access point named: ");
Serial.println(ssid);
//Create the Access point
status = WiFi.beginAP(ssid,pass);
if(status != WL_AP_LISTENING){
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10 seconds for connection:
delay(10000);
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
printWiFiStatus();
ct++;
Serial.println(ct);
a=true;
PLCIn.a_sh=a;
a=false;
PLCIn.a_sh=a;
delay(2000);
if (status != WiFi.status()) {
// it has changed update the variable
status = WiFi.status();
if (status == WL_AP_CONNECTED) {
// a device has connected to the AP
Serial.println("Device connected to AP");
// a device has disconnected from the AP, and we are back in listening mode
Serial.println("Device disconnected from AP");
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your Wi-Fi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
After uploading you have to open the serial com in order for the setup to complete. The board also connects to the PLC IDE without trouble. Apparently it got stuck when opening the serial com and that is why the IDE would freeze.
