Hello. Unfortunately this has now cost me the project but for my sanity I would like to know the issue. I have some experience with C++ but mainly C# so basic errors, or lack of understanding of the Arduino are likely.
We were using an Uno R3, multiplexing (CD74HC4067) 14 ultrasonic range finders (Halija Seafront 5V). Sensors were positioned around a rectangular base to give ~360 coverage for people approaching to control a strip of LEDs - for art..
Calibrating a baseline value from either setup() or loop() (multiple approaches were attempted), and storing these values to be compared with real time data in loop() resulted in (apparent) memory leaks in Serial.
The programme compiles to 24% memory and 41% RAM to sample, compare, calculate the LED response and turn on the lights, then repeat. The output and light functions are removed and commented (//):
//Main.ino
* IF PERSON COMES WITHIN THE GL_interactionRange FADE LIGHTS TO INTERACTION COLOUR
* CALCULATE DISTANCE FOR ALL SENSORS WITHIN INIT CYCLE - SET TO GL_DEFAULTRANGE[]
* ONLY ACCEPT VALUES BELOW THIS DEPTH
#include <FastLED.h>
#define GL_numOfSensors 14
#define GL_lightDataPin 12
#define GL_sensorInitCycles 20 //(20) No. of cycles to initialise the sensors
#define GL_maxDetectionRange 800
#define GL_interactionRange 70.0
byte GL_pingPin = 9;
byte S0 = 8; // MULTIPLEXER PINS
byte S1 = 7;
byte S2 = 6;
byte S3 = 5;
byte GL_echoPin = 13;
byte GL_pinsForInput[1] = { GL_echoPin };
byte GL_pinsForOutput[5] = { S0, S1, S2, S3, GL_pingPin };
int GL_sensorDefaultRange[GL_numOfSensors] = {}; // Static objects data []
int GL_sensorData[GL_numOfSensors] = {}; // Global SensorData []
*PROBLEM STARTS WITH GL_DefaultRange[] allocation and use throughout the programme
initSensors(); //This sets DefaultRange[] before real time data
//initOutputs();
Serial.println( "STARTING" );
byte _idCounter = 5;
* DEBUG - write all sensor numbers each 5 lines for ease of reading data
if( _idCounter == 5 )
_idCounter = 0;
for( byte id = 0; id < GL_numOfSensors; id ++ )
Serial.print(id);
Serial.print(" ");
Serial.print( GL_sensorDefaultRange[id]); // Sanity check the default ranges
Serial.print(" ");
_idCounter++;
// SensorManager - Calculate all depths and set - GL_sensorData[GL_numOfSensors]
getDepthFromAllSensors();
// DetectionManager - Find the nearest sensor value within interaction and default ranges
// Use this value to set the fade of the LEDs in the LightManager - for(ALL LEDS).setHue( %total fade )
identifyPeople();
// OutputManager - Select outputs based proximity - Light / Sound
// Currently only turns on lights - FastLED.Show();
//LightAndSound();
// Wait for system to stabilize - multiple delays in sensor code
delay(20);
initSensors() is handled by SensorManager, below:
//SensorManager.ino
* SET ALL PINS FOR MULTIPLEXER - CYCLE THROUGH ALL SENSORS FOR GL_sensorInitCycles
* SET THESE - GL_DefaultRange[] = GL_SensorData[] (stable from init cycles)
* THIS ASSIGNMENT APPEARS TO CAUSE THE ISSUE WHEN THE GL_DefaultRange[] IS QUERIED
* WHEN COMMENTED OUT THERE DOES NOT APPEAR TO BE AN ISSUE
volatile byte initCounter = 4;
volatile bool sensorsInit = true;
int _inDepth = 0;
void initSensors()
for( int initPin = 0; initPin < 5; initPin++ )
pinMode( GL_pinsForOutput[initPin], OUTPUT );
digitalWrite( GL_pinsForOutput[initPin], LOW );
pinMode( GL_echoPin, INPUT );
for( byte calib = 0; calib < GL_sensorInitCycles; calib++ )
delay(20);
Serial.print(calib);
Serial.print(" ");
Serial.println("Calbiration values");
for( byte cal_ID = 0; cal_ID < GL_numOfSensors; cal_ID++ )
volatile int val = GL_sensorData[cal_ID]; // Assigning a new local variable to separate the
// memory locations - this was a guess instead of
// direct assignment between arrays
GL_sensorDefaultRange[cal_ID] = ( val - 5 ); //(-5) Allow for small amount of noise after stabilised
Serial.print(GL_sensorDefaultRange[cal_ID]); // Sanity check
Serial.print(" ");
int _depth = 0;
void getDepthFromAllSensors()
for( byte sensorID = 0; sensorID < GL_numOfSensors; sensorID++ )
selectMuxPin(sensorID);
_depth = ( getDuration() * 0.034 / 2 );
if ( _depth != 0 )
GL_sensorData[sensorID] = (( 2 ) * GL_sensorData[sensorID] + _depth ) / 3;
Serial.print("id ");
Serial.print( i );
Serial.print(" data ");
Serial.print( _depth );
Serial.print(" ");
Serial.print(GL_sensorData[i]);
delay(20);
//Serial.println();
for( byte outSensorID = 0; outSensorID < 14; outSensorID++ )
Serial.print(GL_sensorData[outSensorID]);
Serial.print(" ");
long getDuration()
long _duration = 0;
// Set the sonar to zero and wait to stabilize
digitalWrite( GL_pingPin, LOW );
delayMicroseconds(200);
// Set the sonar to high - wait for 8 pulses - set to zero
digitalWrite( GL_pingPin, HIGH );
delayMicroseconds(30);
// Read the time of flight - calculate the distance
_duration = pulseIn( GL_echoPin, HIGH, 20000 );
return _duration;
void selectMuxPin( int pin )
for( byte index = 0; index < 16; index++ )
if( pin & (1<<index))
{ digitalWrite( GL_pinsForOutput[index], HIGH ); }
{ digitalWrite( GL_pinsForOutput[index], LOW ); }
Sanity checks in Serial show the GL_DefaultRange[] to be populated, however, when querying this array against the GL_sensorData[] there is a persistent error in the Serial output. See top DEBUG (counter==5) in main loop(). The "id" values shown here give an inconsistent "?" character - suggesting a memory leak. Comparison is made here DetectionManager - identifyPeople():
int closest = GL_maxDetectionRange; // Outside of sensor range
volatile int sensorData = 0;
void identifyPeople()
// Reset tests for nearest person and lightDepthData
for( byte _sensorID = 0; _sensorID < GL_numOfSensors; _sensorID++ )
sensorData = GL_sensorData[_sensorID];
Serial.print( _sensorID );
Serial.print( " sml " );
Serial.print( sensorData );
Serial.print( " " );
Serial.print( GL_sensorDefaultRange[_sensorID] );
// If data is less than the default range and closest
// Possible braces on each && clause may help
if( sensorData < GL_sensorDefaultRange[_sensorID] && sensorData < closest )
closest = sensorData;
Serial.println( closest );
Serial.print( "closest " );
Serial.print( closest );
fadeAll( closest ); // Calculate %fade required (background to full interaction) For all LEDs
// This all works fine
Whenever these two sets of arrays are compared there is a Serial issue. The "volatile int val" in initSensors() is used to attempt to separate the memory locations in assignment, although this was a best guess at a memory allocation issue.
Other than this I cannot think of why the values held in GL_DefaultRange[] cannot be compared with GL_sensorData[]. For the sake of this issue the system appears stable and relatively responsive given the number of delays and smoothing in sensor data, without moving over to the NewPing library, and would have resulted in a completion of the project.
Any and all help would be greatly appreciated as I'd love to know why I couldn't get over this final hurdle in delivering the project. Sorry for any issues with the post. All the best.
