I'm working with a Nano (chinese clone), and a DFPlayer Mini.
I've got it working fine using usb power.
But I need to power the arduino and the miniplayer via batteries.
No matter what I do, if I use external power, I can't get it to work.
To even get the player to turn on, I need to put 5.7v in (the max an open frame 5v supply I have will supply). Then the player lights up, but doesn't work.
Anything less and the player doesn't even light up.
I've tried various batteries (3x 1.5v aaa, 4x1.5 etc, 2 x cr2032's, 1 x 18650 etc). Arduino turns on, but no light on the DFPlayer Mini.
I am putting power in to the arduino via 5v and gnd, and taking power out to the player from the same pins.
I need to use small batteries because it's for a small device. I'll be putting it to sleep most of the time, and also doing the usual hacks when ready to package (it's a one-off gift) - ie, taking power LED off, cutting out regulator etc. I don't want to use VIN as I want to keep the power/batteries as low as possible to run this. It is doing nothing most of the time, except for listening for a button press then waking up and playing something on the miniplayer, then going to sleep again after a while if nothing else is pressed.
Am I doing something wrong?
Once I can actually get it powered externally then I can perhaps get some advice on the best batteries, but at the moment, no external power is working, only USB!
The only other connections are RX,TX from arduino (10,11) - both with 1k resistors - to TX,RX on the player, GND from arduino to GND on player, 5v from arduino to vcc on player, then spk1 and spk2 from player to single small speakers (tried a few, one I'll be using is from a toy and I can't tell what it is, but tiny, but one I do know is 8 ohm, 0.5w).
Thanks
ps. originally asked a similar question but with more questions in the Audio section but thought this section may be more relevant so will put a link from there to here.
