Hii All
i am making simple client server model with two Nodemcu's to send encrypted data from the client and decrypt the data at the server
here are the code that i used
server
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
const char* ssid = "ESP8266-Access-Point";
const char* password = "123456789";
#include <Crypto.h>
#include <base64.hpp>
#define BLOCK_SIZE 16
uint8_t key[BLOCK_SIZE] = { 0x1C,0x3E,0x4B,0xAF,0x13,0x4A,0x89,0xC3,0xF3,0x87,0x4F,0xBC,0xD7,0xF3, 0x31, 0x31 };
uint8_t iv[BLOCK_SIZE] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
void bufferSize(char* text, int &length)
int i = strlen(text);
int buf = round(i / BLOCK_SIZE) * BLOCK_SIZE;
length = (buf <= i) ? buf + BLOCK_SIZE : length = buf;
void encrypt(char* plain_text, char* output, int length)
byte enciphered[length];
RNG::fill(iv, BLOCK_SIZE);
AES aesEncryptor(key, iv, AES::AES_MODE_128, AES::CIPHER_ENCRYPT);
aesEncryptor.process((uint8_t*)plain_text, enciphered, length);
int encrypted_size = sizeof(enciphered);
char encoded[encrypted_size];
encode_base64(enciphered, encrypted_size, (unsigned char*)encoded);
strcpy(output, encoded);
void decrypt(char* enciphered, char* output, int length)
length = length + 1; //re-adjust
char decoded[length];
decode_base64((unsigned char*)enciphered, (unsigned char*)decoded);
bufferSize(enciphered, length);
byte deciphered[length];
AES aesDecryptor(key, iv, AES::AES_MODE_128, AES::CIPHER_DECRYPT);
aesDecryptor.process((uint8_t*)decoded, deciphered, length);
strcpy(output, (char*)deciphered);
//Your IP address or domain name with URL path
const char* serverNameTemp = "http://192.168.4.1/temperature";
const char* serverNameHumi = "http://192.168.4.1/humidity";
const char* serverNamePres = "http://192.168.4.1/pressure";
String temperature;
String humidity;
String pressure;
unsigned long previousMillis = 0;
const long interval = 5000;
WiFi.mode(WIFI_STA);
WiFiMulti.addAP(ssid, password);
while((WiFiMulti.run() == WL_CONNECTED)) {
Serial.print(".");
Serial.println("");
Serial.println("Connected to WiFi");
if(currentMillis - previousMillis >= interval) {
// Check WiFi connection status
if ((WiFiMulti.run() == WL_CONNECTED)) {
temperature = httpGETRequest(serverNameTemp);
humidity = httpGETRequest(serverNameHumi);
pressure = httpGETRequest(serverNamePres);
Serial.println(pressure );
Serial.println(pressure.length() );
char charBuf[24];
pressure.toCharArray(charBuf, 24);
Serial.println(charBuf );
Serial.println(sizeof(charBuf));
char decrypted[24];
decrypt(charBuf, decrypted, 24);
Serial.print("Decrypted: ");
Serial.println(decrypted);
delay(2000);
// save the last HTTP GET Request
else {
Serial.println("WiFi Disconnected");
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
// Your IP address with path or Domain name with URL path
http.begin(client, serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "--";
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
and for client
#include "ESPAsyncWebServer.h"
// Set your access point network credentials
char plain_text[] = "1234";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
#include <Crypto.h>
char encrypted[16];
void setup(){
// Serial port for debugging purposes
// Setting the ESP as an access point
Serial.print("Setting AP (Access Point)…");
// Remove the password parameter, if you want the AP (Access Point) to be open
WiFi.softAP(ssid, password);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
void loop(){
encrypt(plain_text, encrypted, 16);
Serial.println(encrypted);
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", encrypted);
bool status;
// Start server
server.begin();
i could receive the encrypted data on the server ,but when i used the decryption function i failed to get back the enciphered text to its orignal plain text
any idea how what is wrong with the code?
thx in advance for ur help
