[Solved] Problem with float from 8-bit Arduino to Due
Hi, I´m trying to receive 3 float from an 8-bit Arduino Mini, which I know that it manage 4 bytes float, in a 12 byte array. But I´m having troubles to convert it to Due´s float because I do not understand at all, how many bytes have a float in the Due, (I think the float in Due it´s like an double, 8 bytes). I hope someone could confirm me that the Due´s float are 8 byte in memory and tell me how to convert a 4 bytes float to a 8 bytes float, I´m trying to do it with "union" with no results.
Thanks and regards.
Update: I found "Sizeof" function in the reference, I will test it on the Due and I will post the results.
Finally it works XD
sizeof() told me that float are 4 bytes long and double are 8 bytes long on Due, I didn’t understood well in the reference :cold_sweat:
//  Test code to send binary data from 9 DOF Razor IMU to Arduino Due
//  Programa de Prueba para comprobar que el Arduino Due recibe correctamente
//  los datos del 9 DOF Razor IMU y los procesa.
//  Miguel Angel Ruiz 2013
const int TOTAL_BYTES = 12 ; // the total bytes in a message
char MESSAGE [12] = {'N','N','N','N','N','N','N','N','N','N','N','N',};  //  String for testing
union y_tag {
    byte by[4];
    float yval;
} y;
union p_tag {
    byte bp[4];
    float pval;
} p;
union r_tag {
    byte br[4];
    float rval;
} r;
float yaw;
float pitch;
float roll;
void setup(){
  delay(3000);
  Serial1.begin(57600);
  Serial.println("Iniciando IMU");
  Serial1.print("#oe0"); // Disable Error Output
  Serial1.print("#ob");  // Binary Output Format Selected
  Serial1.print("#o0");  // Disable Continuos Data Streaming
  delay(3000);
  Serial.println("Arranque listo, comenzando");
  Serial.print("Mensaje de prueba -> ");
  for(int i=0; i<12; i++){
    Serial.print(MESSAGE[i], HEX);
  Serial.println("");
  Serial.print("->");
  Serial1.print("#f");  // Request one frame of data
}// Fin de setup
void loop(){
  if ( Serial1.available() >= TOTAL_BYTES){
        y.by[0] = Serial1.read();
        y.by[1] = Serial1.read();
        y.by[2] = Serial1.read();
        y.by[3] = Serial1.read();
        yaw = y.yval;
        p.bp[0] = Serial1.read();
        p.bp[1] = Serial1.read();
        p.bp[2] = Serial1.read();
        p.bp[3] = Serial1.read();
        pitch = p.pval;
        r.br[0] = Serial1.read();
        r.br[1] = Serial1.read();
        r.br[2] = Serial1.read();
        r.br[3] = Serial1.read();
        roll = r.rval;
        Serial.print("Received IMU msg, Yaw = ");
        Serial.print(yaw, 2);
        Serial.print(", pitch = ");
        Serial.print(pitch, 2);
        Serial.print(", roll = ");
        Serial.println(roll, 2);
 /*    for(int i=0; i<12; i++){          //  Old code for testing
       MESSAGE[i] = Serial1.read();
       Serial.print(MESSAGE[i],HEX);
       Serial.println("");
       Serial1.print("#f");*/
    Serial1.print("#f");                 //  Request another frame of data
}// Fin del loop
