Hi!
I have a arduino mega and ethernet shield.
I configure a web server with php files. If i write in my navigator www.domain.com/iot.php?valor=22.55 the data up correct to mysql.
I modified webcliend example to upload the data to mysqul from arduino mega but not found.
it s the code
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.domain.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,1,177);
float temperatura=39;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
client.print("GET /iot.php?valor=88"); // Enviamos los datos por GET
//client.print(temperatura);
client.println(" HTTP/1.0");
client.println("User-Agent: Arduino 1.0");
client.println();
Serial.println("Conectado");
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
and in serial monitor the arduino write
connecting...
connected
Conectado
HTTP/1.1 404 Not Found
Date: Fri, 17 Oct 2014 11:49:22 GMT
Server: Apache
Content-Length: 324
Connection: close
Content-Type: text/html; charset=iso-8859-1
Not Found
The requested URL /iot.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
disconnecting.
i understand that arduino conect to the server and dont find iot.php but the file is it
