In trying to read EDID data and getting erroneous results. Any pointers would be appreciated.
Proper Data should be
(000) 00 FF FF FF FF FF FF 00 4C AB
(010) 00 00 01 00 00 00 23 17 01 03
(020) 81 56 30 78 8A A5 8E A6 54 4A
(030) 9C 26 12 45 46 AD CE 00 81 40
(040) 01 01 01 01 01 01 01 01 01 01
(050) 01 01 01 01 04 74 00 30 F2 70
(060) 5A 80 B0 58 8A 00 56 E1 31 00
(070) 00 1E 9A 29 A0 D0 51 84 22 30
(080) 50 98 36 00 60 E1 31 00 00 1C
(090) 00 00 00 FD 00 32 4B 18 3C 0B
(100) 00 0A 20 20 20 20 20 20 00 00
(110) 00 FC 00 53 45 33 39 55 59 30
(120) 34 0A 20 20 20 20 01 65
Data return with 32 byte Wire.requestFrom() calls. One byte after every 32 is missed.
(030) 9C 26 45 46 AD CE 00 81 40 01 (should read - 9C 26 **12** 45 46 AD CE 00 81 40)
(050) 01 01 01 04 74 00 30 F2 70 5A
(060) 80 B0 58 8A 56 E1 31 00 00 1E
(070) 9A 29 A0 D0 51 84 22 30 50 98
(080) 36 00 60 E1 31 00 00 1C 00 00
(090) 00 FD 00 32 4B 18 0B 00 0A 20
(100) 20 20 20 20 20 00 00 00 FC 00
(110) 53 45 33 39 55 59 30 34 0A 20
(120) 20 20 20 01 65 02 03 2A
Data return with 16 byte Wire.requestFrom() calls. One byte after every 16 is missed.
(010) 00 00 01 00 00 00 17 01 03 81 (should read - 00 00 01 00 00 00 **23** 17 01 03)
(020) 56 30 78 8A A5 8E A6 54 4A 9C
(030) 26 12 46 AD CE 00 81 40 01 01
(050) 01 04 74 00 30 F2 70 5A 80 B0
(060) 58 8A 00 56 31 00 00 1E 9A 29
(070) A0 D0 51 84 22 30 50 98 36 00
(080) E1 31 00 00 1C 00 00 00 FD 00
(090) 32 4B 18 3C 0B 00 20 20 20 20
(100) 20 20 00 00 00 FC 00 53 45 33
(110) 39 55 30 34 0A 20 20 20 20 01
(120) 65 02 03 2A 71 4F 06 07
Sample code below.
#include <Wire.h>
#define EDID_LENGTH 128
Wire.begin();
ddcRead(32);
ddcRead(16);
void ddcRead(byte req_size) {
byte i = 0;
byte edidbyte;
Wire.beginTransmission(0x50);
Wire.write(byte(0x00));
Wire.endTransmission();
delay(100);
Serial.print(req_size);
Serial.println(" bytes at a time");
for (int block = 0; block < (EDID_LENGTH / req_size ); block++) {
Wire.requestFrom(0x50, req_size);
while (Wire.available() && i < EDID_LENGTH) {
edidbyte = Wire.read();
if (i % 10 == 0) {
Serial.print(" (");
if (i < 10) Serial.print(0);
if (i < 100) Serial.print(0);
Serial.print(i);
Serial.print(") ");
if (edidbyte < 16) Serial.print(0, HEX);
Serial.print(edidbyte, HEX);
Serial.print(" ");
i++;
Serial.println("********");
