[Solved] Problem with passing variables by reference to a function
SO I have been experimenting with returning multiple values from a function, based on information I found in this thread at http://forum.arduino.cc/index.php?topic=48604.0 I wrote a small sketch to test out the method here:
boolean Fcn(int inval, int &outval)
outval=2*inval;
return (((inval/2)*2) == inval);
int progval[2];
Serial.println("Number = 1");
if( Fcn(1,progval[1]) ) {
  Serial.println("Number is even");
  Serial.println("Number is odd");
Serial.print("Output = ");
Serial.println(progval[1]);
Serial.println("Number = 4");
if(Fcn(4,progval[2])) {
Serial.println(progval[2]);
while(true){}
It works as designed. The function returns “true” if the first parameter is even; “false” if it is odd. In “outval”, the function returns twice the “inval” value". So I decided to incorporate passing function parameters by reference in my actual code. The function “readln_ACode” is supposed to return four integers, read from a comma separated values file on an SD card. If I make the four variables global and define the function with no parameters - it works. However, if I define the parms local and pass them by reference, I get strange results. Zeroes for most of the integers and 25956 for one of them. (I mention the vaue, in case it triggers something). As I see it, it is a simple change which should work. I could use global parameters, but this needlessly uses extra variables and conplicates the code. The final storage for these integers is a set of four arrays. If anyone can see what I am doing wrong, I’d appreciate it. Been working on the problem for a couple of days. Here is the code:
  SD card acode file read
  Notes:
  function returns reference at http://forum.arduino.cc/index.php?topic=48604.0
#include <SPI.h>
#include <SD.h>
File myFile;
boolean  readln_ACode(int &action, int &desc, int &option, int &stack)
  String inputstring="";
  int inputvalues[4];
  byte inputchar;
  byte index=1;
  boolean Done=false;
  inputchar='\0';
  while ((! Done) && (myFile.available())) {
    inputchar=myFile.read();
    if (inputchar==',') {
    // comma found, have chars for number
      inputvalues[index]=inputstring.toInt();
      index ++;
      inputstring="";
      if (inputchar == 13 ) {
        // EOL found; last number found
        Done = true;
        if (inputchar >= '0' && inputchar <='9') {
           // character is a digit; append to string
           inputstring=String(inputstring+String(char(inputchar)));
           inputstring="";
  action  =inputvalues[1]; // all Global variables
  desc    =inputvalues[2];
  option  =inputvalues[3];
  stack   =inputvalues[4];
  return myFile.available();
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  if (SD.exists("acode.txt")) {
    Serial.println("acode.txt exists.");
  else {
    Serial.println("acode.txt doesn't exist.");
  // open file
  Serial.println("Opening acode.txt...");
  myFile = SD.open("acode.txt");
  int saction;
  int sdesc;
  int soption;
  int sstack;
  boolean More=true;
  while (More) {
    More=readln_ACode(saction,sdesc,soption,sstack);
    if (More) {
      Serial.println(saction);
      Serial.println(sdesc);
      Serial.println(soption);
      Serial.println(sstack);
  while(true){}
  int inputvalues[4];
A 4-element array has indexes 0, 1, 2, and 3; not 1, 2, 3, and 4.
What is happening here?
           inputstring="";
Looks like you carefully add the latest char to your inputstring and immediately throw the whole thing away.
djsfantasi: If anyone can see what I am doing wrong, I'd appreciate it.
Local variables in a function are only valid from - starting the function - until the function ends
So these local variables in your loop become invalid each time the loop is finished:
  int saction;
  int sdesc;
  int soption;
  int sstack;
Next time the loop begins, the value of these integers is "not defined" any longer. Maybe random numbers from re-used RAM sections.
If you want that local defined variables keep their contents from one function execution to the next function execution, you would have to declare them "static":
  static int saction;
  static int sdesc;
  static int soption;
  static int sstack;
Then those variable keep living and keep their contents, even when the function ends, just like "global" variables, but with a local scope of visibility.
jurs:
  • starting the function
  • until the function ends
Understood, Jurs. This is the loop function, and I want and expect these variables to be local.
johnwasser:
Thank you for noticing, John. I had (wrongly) assumed that array[4] had the elements 0-4.
wildbill:
inputstring="";
Bingo! That line to “throw the whole thing away”, belonged in the else block above. After extracting the integer value, I wanted to clear the string. Great catch! I needed to follow my own advice when something inexplicably stops working - ask “what DIDN’T you change”! Ha ha. It was supposed to be a simple copy and paste. Helps when you paste it in at the correct line.
