[SOLVED] Problem with snprintf and signed and unsigned long
Hi
I want to use signed long and unsigned long with snprintf. after some reading up I think I should use the ul and il tag.
However that does not give me the wanted result.
For instance:
  static unsigned long smallUnsigned =1;
  static unsigned long bigUnsigned =100000;
  static unsigned long smallSigned =-100000;
  static unsigned long bigSigned =100000;
  char printBuffer[100];
  snprintf(printBuffer,sizeof(printBuffer),"smallUnsigned =%ul",smallUnsigned++);
  Serial.println(printBuffer);
  snprintf(printBuffer,sizeof(printBuffer),"bigUnsigned =%ul",bigUnsigned++);
  snprintf(printBuffer,sizeof(printBuffer),"smallSigned =%il",smallSigned++);
  snprintf(printBuffer,sizeof(printBuffer),"bigSigned =%il\n",bigSigned++);
  delay (1000);
creates following output (that is from the start)
smallUnsigned =1l
bigUnsigned =34464l
smallSigned =31072l
bigSigned =-31072l
smallUnsigned =2l
bigUnsigned =34465l
smallSigned =31073l
bigSigned =-31071l
smallUnsigned =3l
bigUnsigned =34466l
smallSigned =31074l
bigSigned =-31070l
smallUnsigned =4l
bigUnsigned =34467l
smallSigned =31075l
bigSigned =-31069l
smallUnsigned =5l
bigUnsigned =34468l
smallSigned =31076l
bigSigned =-31068l
The last character is always a l which indicates it is not interpreted. As such all the longs are interpreted as ints and return wrong values as soon as the MSB is used.
Do I use the wrong tag or is this a bug?
Best regards
Jantje
Is that your real code? You don't call Serial.begin() so I wouldn't expect to see any output at all.
This sketch:
  static unsigned long bigUnsigned = 0xFFFFFFFF;
  static long bigSsigned = -200000;
  snprintf(printBuffer, sizeof(printBuffer), "The unsigned output is '%lu'", bigUnsigned);
  snprintf(printBuffer, sizeof(printBuffer), "The signed output is '%ld'", bigSsigned);
produces this output:
The unsigned output is '4294967295'
The signed output is '-200000'
Edit : changed the example to include large signed negative and unsigned positive values.
yes it is the real code.
Seems it works on the yun with minicom without the serial.begin();.
Anyway you are using lu and li instead of ul and li :D. Using those it works great :smiley:
So thank you very much
Best regards
Jantje
