[SOLVED] Problems containing an object within a class
I'm Building a quadcopter using 4 brushless motors (Radio Control Planes, Drones, Cars, FPV, Quadcopters and more - Hobbyking). These can be controlled by the Servo library but due to the library being incompatible with VirtualWire (radiocontrol), I'm using the ServoTimer2 library instead.
Following the normal procedure I'm able to make the motor spin with a simple code:
#include <ServoTimer2.h>
#include <VirtualWire.h>
ServoTimer2 _servo;
  _servo.attach(12);
  _servo.write(2000); // Im using a scale from in the interval 1200 - 2000
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  if(Serial.available() > 0)
    char incomingChar = Serial.read();
    if(incomingChar == '1')
      _servo.write(2000); // Maximum power
      digitalWrite(13, HIGH);
    } else if(incomingChar == '0') {
      _servo.write(1200); // Minimum power
This all works as expected. However when I try to put it into a class, nothing happens. The program compiles without warnings and I can see the onboard LED change state upon my requests:
class Motor
  private:
    ServoTimer2* _servo;
  public:
    Motor(int pin)
      _servo = new ServoTimer2();
      _servo->attach(pin);
      setSpeed(0);
    // Hvor speed er et tal mellem 0 - 100
    void setSpeed(int speed)
      // Accelerer ligeså stille
      speed = min(100, max(0, speed));
      speed = map(speed, 0, 100, 1200, 2000); // Look at http://forum.arduino.cc/index.php/topic,21975.0.html for specification
      _servo->write(speed);
Motor m1(12);
    pinMode(13,OUTPUT);
    m1.setSpeed(0);
      m1.setSpeed(0);
    } else if(incomingChar == '1'){
      m1.setSpeed(100);
I'm not used to coding in C++ so my attempt with the pointer is probably wrong, however removing the pointer and using it exactly like the m1 object does not work either. What am I doing wrong?
Best regards
Morten
Managed to solve it by using pointers outside the class (initialization of the servos/pins will then happen in the setup method, not before):
class Motor
  private:
    ServoTimer2 _servo;
  public:
    Motor(int pin) : _servo()
      _servo.attach(pin);
      setSpeed(0);
      _servo.write(speed);
Motor *m1;
int pin_m1 = 12;
  m1 = new Motor(pin_m1);
  if(Serial.available())
    Serial.read();
    m1->setSpeed(100);
To read more about how it works, take a look at Classes within Classes - Initialiser Lists
Thanks, this was exactly my problem and you pointed me on the right direction! I had to remove the "extern" from my library but hey, it works. This was by far the hardest fix to find as a newbie :o
The ServoTimer2 works perfect now (although at first I didn´t get the unit change between degrees and miliseconds when setting the servo position, so I was only getting really slow movements).
Anyway, thanks for taking the time to post this, I was totally stuck. The ServoTimer2 package should include some information about this common incompatibility problem if you use the Wire library..
