I have issues with a genuine arduino Leonardo, purchased only a few days ago, any help would be very greatly appreciated. I may even pay you in hugs.
I have tried an assortment of fixes that have worked for other people on these forums but not a single one has worked for me
Things I have tried
- Restarting
- Using a different cable
- Trying it on a different computer/OS
- Using a different board of the same model that is known to work
- Manually installing drivers
- Using both USB 3.0 and 2.0 ports
- Using a powered USB hub
- Resetting the leonardo, several times
- I have tried uninstalling and reinstalling the USB
Details about my issue
- Arduino leonardo is not recognised by windows
- Arduino drivers will not install for this device, automatically or manually
- Upon trying to install drivers I often encounter error 43 and the standard fixes for this error don't work
- Upon trying to install drivers from the .../arduino/Drivers folder I get "The best driver software for your device is already installed"
- Upon trying to manually pick the driver to install and using the 'Have Disk' option i get "The folder specified does not contain a compatible software driver to work with your device...."
- I am using offical drivers that came with the Arduino software downloaded from http://arduino.cc/en/Main/Software
- FTDI drivers are all installed
Details about the arduino:
- Arduino appears as unknown device, under the "Universal Serial Bus Controller" class in device manager
- Device has an unknown PID and VID and unknown compatible ID's
- Arduino Leonardo On light (green) is on, but the L light *Yellow/Orange" begins on, but then fades off
- Arduino leonardo is connected via standard USB cable
- Arduino has yet to be used
- Arduino appears physically intact
Details about the computer
- PC is a HP pavilion DV6 PC
- Running on 6 gb of ram and a 500mb Hard Drive
- It runs smoothly for nearly everything else
- I have tried using the Arduino 1.0.5 and 1.5.7 and even the Arduino ERW 1.0.5
