My sketch "I2C_scanner.ino" works fine on a Arduino Mega 2560.
The computer recognizes port Com 4 (text: "Com 4 (Arduino/Genuino Mega or Mega 2560).
When I restart the IDE with the same sketch when it is connected to a Arduino Nano, I only see in a box "Serial ports, Cim1, Com3 and Com 5", but no confirmation that the Nano is recognized.
Uploading the sketch will never end.
Enclosed an overview of the ports (via the control panelen). I removed and reinstalled the devicedriver "USB-Serial CH 340 (Com5)".
Is ther a working solution for connecting the Arduino Nano?
Select Tools > Port > COM5 from the Arduino IDE's menus.
Select File > Preferences from the Arduino IDE's menus.
Uncheck the checkbox next to Show verbose output during: [] compilation
Check the checkbox next to Show verbose output during: [] upload.
Click the OK button.
Attempt an upload, as you did before.
Wait for the upload process to hang.
Click on the black console pane at the bottom of the Arduino IDE window.
Press Ctrl+A to select all the text.
Press Ctrl+C to copy the selected text to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V. This will paste the error output from the upload into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
ArduinoStarter1: I only see in a box "Serial ports, Cim1, Com3 and Com 5", but no confirmation that the Nano is recognized.
That's the expected behavior. Your Nano uses a USB-serial chip (CH340) with a generic VID/PID so there is no way for the Arduino IDE to identify that COM5 is a Nano. The USB-serial chip on official Mega 2560 and faithful clones use a programmable USB-serial chip which has a VID/PID specific to the Mega 2560 so the Arduino IDE is able to label the Mega's port in the Tools > Port menu.
I found if you select TOOLS>Processor>"old bootloader" seems to work. Strangely I only have this problem on some nanos others are fine. Guess that is just the chip selection they use.
If you have a Programmer, (connects to SCK-MOSI-MISO, Reset, Power, Gnd) you can re-bootload them as Uno and take advantage of the latest bootloader.
I bootload all my 328Ps as an Uno.
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\staff\AppData\Local\Temp\arduino_build_989124/sketch_may16a.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x40
haripm033:
Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE's menus and then try uploading again.
OK, then that means you're using an old version of Arduino AVR Boards. If you have an official Arduino Nano that was purchased in 2018 or 2019 you need to use the latest version of Arduino AVR Boards with Tools > Processor > ATmega328P selected in order to upload.
Try this: Tools > Board > Boards Manager Wait for the downloads to finish. Click on "Arduino AVR Boards by Arduino". Click the "Update" button. Wait for the update to finish. Click the "Close" button.
I'm getting the Permission Denied error with Chinese and genuine nanos and Unos, including ones I bought 2 years ago that have been uploaded to MANY times without a problem. After trying all the fixes I've seen on Win10 I've been trying on a brand new Ubuntu 18 install (different physical box, not dual boot), only to find the exact same behavior.
Does anyone know a different solution from the ones mentioned here, or a reason why none of these would work?
I have an older nano, I would like to use, but I didn' t can connect. In the device manager writes "pashed out since 2012". What do you think about is this problem? I use the old bootloader
Can anybody give me advice?
THX
Sketch uses 12072 bytes (39%) of program storage space. Maximum is 30720 bytes.
Global variables use 1030 bytes (50%) of dynamic memory, leaving 1018 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\YACOUB~1.OUA\AppData\Local\Temp\arduino_build_942576/MultiWii.ino.hex:i
avrdude: Version 6.3-20190619
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0c
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Uno"
Sketch uses 1008 bytes (3%) of program storage space. Maximum is 32256 bytes.
/private/var/folders/5d/0nj7w8qs7qg_wp44cchsnz4r0000gn/T/AppTranslocation/50E201C2-E433-4BDD-B1B4-8FF674388E91/d/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/5d/0nj7w8qs7qg_wp44cchsnz4r0000gn/T/AppTranslocation/50E201C2-E433-4BDD-B1B4-8FF674388E91/d/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-1410 -b115200 -D -Uflash:w:/var/folders/5d/0nj7w8qs7qg_wp44cchsnz4r0000gn/T/arduino_build_249094/Vihu-02.ino.hex:i
System wide configuration file is "/private/var/folders/5d/0nj7w8qs7qg_wp44cchsnz4r0000gn/T/AppTranslocation/50E201C2-E433-4BDD-B1B4-8FF674388E91/d/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/mahendergadipally/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-1410
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
gadipally:
Which Arduino board are you using? This thread is about the Arduino Nano, but the error message shows you have the Arduino Uno selected in the Arduino IDE's Tools > Board menu.
