I'm trying to burn the bootloader on an ATmega8 using an Arduino Duemilanove with ATmega328, no success so far. I using Arduino software 1.0.1 on Windows 7 64-bits.
What I have done so far:
uploaded ArduinoISP sketch to the Arduino using COM3 (tested Arduino before with Blink sketch, everything is fine);
after error code "avrdude: stk500_getsync(): not in sync: resp=0x15" and googled it, discovered that I need to disable auto-reset, done that with a 115 ohms resistor connecting Reset pin to 5V pin (a bunch of resistors in parallel as a matter of fact). Source: EngineeringException: A note of caution for Arduino ISP
In Tools ? Board, chose "Arduino NG or older w/ ATmega8"; in Programmer, chose "Arduino as ISP";
Tried to burn bootloader, got this error message:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
I'm trying to burn the bootloader on this ATmega8 just because it's not being used anywhere and I had an idea that would be just fine using it. My hope is that the ATmega8 isn't fried as it was on my shelf for a long time, it's complicated to get another one here in Brazil. :-/
protocol error, expect=0x14, resp=0x50 - this part of the error message says that the configuration is expecting a different chip, or version of the chip. The chips have a couple "signature bytes" that AVRDudue checks to see if the correct chip is connected and the signature isn't correct. May not be a problem - ATMega328 and ATMEGA328P do this.
What system are you using this on, and how comfortable are you playing around with a DOS prompt?
kf2qd:
As I said previously, I'm trying to burn the bootloader on an ATmega8 using an Arduino Duemilanove w/ ATmega328 as ISP, using Arduino 1.0.1 in a Windows 7 64-bit system. And I am pretty confortable with the command line, that's not a problem.
I discovered the problem: my bread board is just some piece of s*** that doesn't connect all the outer pins in the correct manner. Discovered that by accident, but now everything is working just fine, thank you everyone who answered me.
