[solved]PROGMEM not usable in header files
hi,
PROGMEM can only be used within a sketch.
Using it within a header file causes compiler errors.
Does it?
Please post a short sketch and header file exhibiting the error. By short, I mean just enough to exhibit the error and no more. I'd expect your header to be just the variable declaration, and the .ino to be a setup and loop that references that variable.
Would you care to provide any details?
code in a .h file is treated identically to code in a sketch.
Note that some system .h files are automatically included in a sketch, and you may be required to include them manually in a .h or .cpp file, depending on exact positioning of the #include.
That is incorrect. Trying to use PROGMEM in a class, defined in a header file, is a different story.
Quit making unsubstantiated claims. Post some proof. Otherwise, you come across as a clueless dweeb. I'm sure that is not your intent.
From your responses I guess that perhaps some includes are missing, but which of them?
The first part of the header file is (there are no includes):
#ifndef    EPD_H
  #define  EPD_H
#define    // at lot of defines here
const int arrow_y[] PROGMEM = {-98, -98, -60, -98, -83, -55, -83, -56, -42, -56, -20, -23};
The error message from compiler is:
In file included from sketch\epd.cpp:14:0:
epd.h:94: error: expected initializer before 'PROGMEM'
const int arrow_y PROGMEM = {-98, -98, -60, -98, -83, -55, -83, -56, -42, -56, -20, -23,
exit status 1
avr/pgmspace.h
avr/pgmspace.h
That's it. Thank you very much.
SupArdu
