SOLVED programming an attiny
I am trying to programme an attiny. I have succeeded in designing and building a small board that fits on the UNO and with the ArduinoISP program in the UNO have programmed a version of the blink program into the attiny and successfully run it.
Now I want to programme something more serious into it.
According to this page the instruction set is very tiny. Is this true? Does it not even include things like IF and FOR? if this is so how do you write this?
  for (int a=0;a<160;a=a+16)
  digitalWrite(LATCH, LOW);                //Latch Low
  shiftOut(SER, CLK, LSBFIRST, a); //Send data, Most Significant Bit first
  digitalWrite(LATCH, HIGH);               //Latch High - Display setting
  delay (500);
I ask because I have tried to enter this to run the higher half of instructions for a shift register and it shows the first instruction but doesn’t count up, this is the only reason I can see why.
Same general instruction set as other Arduinos… Whatever is provided for in the core.
There is only 512 Bytes of SRAM in the tiny85, 25% of a 328 UNO. But it can be a rather powerful device. I think I have 3 or 4 tiny85 projects… Look over the code mrburnette projects
Below is one t85 example using as thermistor and RGB LED.
Ray
   M. Ray Burnette 20140210 Open Source: for "Hot Yet?" publication
   Coding Badly Tiny core: https://code.google.com/p/arduino-tiny/
   Binary sketch size: 2,852 bytes (of a 8,192 byte maximum)
   Arduino 1.0.5 No bootloader used.  Upload via ISP.
   Project 3.3V Attiny85 @8MHz internal,  under 10mA idle at 68F
   Schematic:
   x-----------------/\/\/\/\/\/\/\/---------------x---/\/\/\/\/\/\/\----xGND
   |                NTC 10K Thermistor             |  10K 1% Resistor
   |              ATTINY85 / ARDUINO               |
   |    Ain0 (D 5) PB5  1|    |8  Vcc              |
   x--- Ain3 (D 3) PB3  2|    |7  PB2 (D 2) Ain1 ---
(Blue)- Ain2 (D 4) PB4  3|    |6  PB1 (D 1) pwm1  (Green) ----------|<---x
   |               GND  4|    |5  PB0 (D 0) pwm0  (Red) ------------|<---x
   |                     +----+                                          |    100 Ohm
   x----------------------------------------------------------------|<---x---/\/\/\/\/---Vcc 3.3V
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/wdt.h>
boolean flag_wdt = 1;
int pinT = PB3;           // Thermistor source voltage
int pinR = PB0;           // Digital pin #0  Red
int pinG = PB1;           // Digital pin #1  Green
int pinB = PB4;           // Digital pin #4  Blue
int r; int g; int b;
const int nToSleep = 50 ; // # of stable temp readings before sleep
const int Delay =    100; // main loop delay in mS
double ADCcount;
double ADCprevious;
int nCount;
int ThermistorPin  = 1 ;  // A1 is physical pin #7 (PB2)
  // WDTO_15MS, WDTO_30MS, WDTO_60MS, WDTO_120MS, WDTO_250MS, WDTO_500MS,
  // WDTO_1S, WDTO_2S, WDTO_4S, WDTO_8S
  setup_watchdog(WDTO_4S);  // Periodic Heartbeat to awaken deep sleep()
  sleep_disable();
  pinMode(pinT, OUTPUT); digitalWrite(pinT, HIGH);  // Thermistor Source
  pinMode(pinR, OUTPUT);
  pinMode(pinG, OUTPUT);
  pinMode(pinB, OUTPUT);
  wdt_reset();    // pat K9
  ADCcount = analogRead(ThermistorPin) ;
  if (ADCcount == ADCprevious) ++nCount;
  if ( nCount > nToSleep )
  { // prepare for low current power-down state
    pinMode(pinR, INPUT); digitalWrite(pinR, HIGH);  // pullup enabled
    pinMode(pinG, INPUT); digitalWrite(pinG, HIGH);
    pinMode(pinB, INPUT); digitalWrite(pinB, HIGH);
    SleepLonger:    // Come here to re-sleep
    pinMode(pinT, INPUT); digitalWrite(pinT, HIGH);
      system_sleep();
      sleep_disable();  // deep sleep until WDT kicks
      delay(50);
      // Yawn, exercise a few reads for stabilization
      for (uint8_t z=0; z<5; z++) {
      if (abs(ADCcount - ADCprevious) < 4) goto SleepLonger;  // hysteresis
    // restore LED output drivers ... temp has gone up
    pinMode(pinR, OUTPUT); digitalWrite(pinR, HIGH);
    pinMode(pinG, OUTPUT); digitalWrite(pinG, HIGH);
    pinMode(pinB, OUTPUT); digitalWrite(pinB, HIGH);
    nCount = 0;
  // 261 = 32F, 447 = 64F, 537 = 75F, 575 = 82F
  b = map(ADCcount, 261,  447, 100, 255 );
  g = map(ADCcount, 435,  574, 250, 100);  // overlap green & blue
  r = map(ADCcount, 575, 1023, 250,  50);
  if (ADCcount > 574)              // HOT: ADCcount goes up with increase temperature
      // Show only Red when Hot with Red intensity increasing with temperature
      analogWrite(pinR,   r);
      analogWrite(pinG, 255);      // 255 = 100% High == NO LED Current Common Anode --> Vcc
      analogWrite(pinB, 255);      // Blue Off
    } else {                       // Cold to Cool transition with Blue fading into Green
      analogWrite(pinR, 255);      // Red Off
      analogWrite(pinG, g);
      analogWrite(pinB, b);        // Brighter Blue with colder temp
  ADCprevious = ADCcount;
  delay(Delay);
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
// http://www.insidegadgets.com/wp-content/uploads/2011/02/ATtiny85_watchdog_example.zip
void system_sleep()
    cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
    power_all_disable ();                // power off ADC, Timer 0 and 1, serial interface
    set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
    noInterrupts ();                     // timed sequence coming up
    sleep_enable();
    interrupts ();                       // interrupts are required now
    sleep_mode();                        // System sleeps here
    sleep_disable();                     // System continues execution here when watchdog timed out
    power_all_enable ();                 // power everything back on
    sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
// 0=16ms, 1=32ms, 2=64ms, 3=128ms, 4=250ms, 5=500ms, 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
void setup_watchdog(int ii)
  byte bb;
  int ww;
  if (ii > 9 ) ii=9;
  bb=ii & 7;
  if (ii > 7) bb|= (1<<5);
  bb|= (1<<WDCE);
  ww=bb;
  MCUSR &= ~(1<<WDRF);
  // start timed sequence
  WDTCR |= (1<<WDCE) | (1<<WDE);
  // set new watchdog timeout value
  WDTCR = bb;
  WDTCR |= _BV(WDIE);
// Watchdog Interrupt Service / is executed when watchdog timed out
ISR(WDT_vect) {
     // wdt_disable();  // disable watchdog
Same general instruction set as other Arduinos..
I wonder then why the link has
With regard to writing a sketch for the ATtiny85, there is only a limited instruction set:
the shift register then drives two BCD to 7 segment chips 74ls48's. The seven segments units go to '0' and then stay there.
Can you think of any other reason for this?
thank you mrburnette.
I have had another look at the attiny and after much teeth gnashing discovered that the small board I had manufactured to convert an attiny to fit my pro mini socket had a dry joint. The latch pin was failing to send its signal causing the output to stay on 0. It works fine now.
thank you for your input and interest.
