[solved] PWM problem on mega 2560
I've setup pwm pins 2 through 7 on my OSEPP 2560 r3 mega compatible board. However, only pwm pins 5, 6, and 7 work. 2, 3, and 4 don't. Currently, I'm only driving LEDs on the output with 470 ohm resistors.
Here's my code:
#define A_HIGH 6 // PWM 2 wrong pin!
#define A_LOW 7 // PWM 3 wrong pin!
#define B_HIGH 1 // PWM 4 wrong pin!
#define B_LOW 5 // PWM 5
#define C_HIGH 15 // PWM 6
#define C_LOW 16 // PWM 7
/* Setup PWM pins */
void setup_pins() {
  pinMode(A_HIGH, OUTPUT);
  digitalWrite(A_HIGH, 1);
  pinMode(A_LOW, OUTPUT);
  digitalWrite(A_LOW, 1);
  pinMode(B_HIGH, OUTPUT);
  digitalWrite(B_HIGH, 1);
  pinMode(B_LOW, OUTPUT);
  digitalWrite(B_LOW, 1);
  pinMode(C_HIGH, OUTPUT);
  digitalWrite(C_HIGH, 1);
  pinMode(C_LOW, OUTPUT);
  digitalWrite(C_LOW, 1);
/* Setup PWM timers/frequency (~31KHz)*/
void setup_pwm() {
  setup_pins();
  setup_pwm();
Why won't pins 2 through 4 work?
Nevermind, got physical pins confused with IDE pins.
