[solved] RFID & Arduino Yun
Hello everyone,
I'm working on a RFID project using this tutorial : http://www.instructables.com/id/Arduino-and-RFID-from-seeedstudio/
Everything work find with my arduino Uno but I can't make it work on my arduino yun.
This is the code I use on both of them :
#include <SoftwareSerial.h>
String msg;
SoftwareSerial RFID(2, 3);
  Serial.println("Serial Ready");
  Serial.println("RFID Ready");
char c;
void loop(){
  while(Serial.available()>0){
    c=Serial.read();
    msg += c;
    Serial.print(msg);  //Uncomment to view your tag ID
  if(msg.length()>10) Serial.println("");
  msg = "";
Even the "Serial.println("Serial Ready");" doesn't work (on arduino Yun) on the setup fonction, but if I put it on loop I see the message.
Have you an idea ?
Thank you,
Maxime
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Look in the YUN forum! Or check the use of serial on the leonardo - it's not the same as that for the Uno.
Mark
Hello,
I look on that.
Thank you
I found the solution on the leonardo's help : http://arduino.cc/en/Reference/SoftwareSerial
Not all pins on the Leonardo support change interrupts, so only the following can be used for RX: 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
the solution
String msg;
SoftwareSerial RFID(10, 11);
  RFID.begin(9600);
char c;
void loop(){
  while(RFID.available()>0){
    c=RFID.read();
    msg += c;
  msg = "";
Thank you Mark
