[SOLVED] Rotary Encoder Interrupt
Im using a rotary encoder to change the brightness of the Blinkm, the blinkm works, it sets to red fine, but the interrupt is not working. the encoder is pins 2 and 3 and common on the encoder is GND. Any ideas?
#include <Wire.h>
#define encoder0PinA  2
#define encoder0PinB  3
volatile unsigned int encoder0Pos = 0;
int value = 0;
  pinMode(encoder0PinA, INPUT);
  digitalWrite(encoder0PinA, HIGH);       // turn on pullup resistor
  pinMode(encoder0PinB, INPUT);
  digitalWrite(encoder0PinB, HIGH);       // turn on pullup resistor
  attachInterrupt(0, doEncoder, CHANGE);  // encoder pin on interrupt 0 - pin 2
 Wire.begin();                // set up I2C on 4 and 5 analog
  Wire.beginTransmission(0x09);// join I2C, talk to BlinkM 0x09
  Wire.send("o");
 Wire.endTransmission();
  Wire.send("c");
  Wire.send(0xff);             // value for red channel
  Wire.send(0x00);             // value for blue channel
  Wire.send(0x00);             // value for green channel
  Wire.endTransmission();      // leave I2C bus         // debug - remember to comment out
                                              // before final program run
void loop(){
// do some stuff here - the joy of interrupts is that they take care of themselves
void doEncoder(){
  if (digitalRead(encoder0PinA) == HIGH) {   // found a low-to-high on channel A
    if (digitalRead(encoder0PinB) == LOW) {  // check channel B to see which way
                                             // encoder is turning
      encoder0Pos = encoder0Pos - 1;         // CCW
    else {
      encoder0Pos = encoder0Pos + 1;         // CW
  else                                        // found a high-to-low on channel A
    else {
   if ( encoder0Pos < 0){
     encoder0Pos =  encoder0Pos + 255;
  else if ( encoder0Pos > 255){
     encoder0Pos =  encoder0Pos -255;
  value =  encoder0Pos;
  Wire.send("c");              // ‘c’ == fade to color
  Wire.send(value);             // value for red channel
  Wire.send(value);             // value for blue channel
  Wire.send(value);             // value for green channel
Why don't you try moving the below Wire statements out of the ISR function and put it into the loop() function. Then run it and see if that solves the problem.
Normally you don't put more into a ISR then you absolutly need to, short and sweet is the rule. Also all system interrupts are disable while inside a ISR so I'm not even sure those wire statements will work inside a isr. Easy to test and see.
Lefty
You legend, works a treat. Karma awarded accordingly.
fliggygeek: You legend, works a treat. Karma awarded accordingly.
Even a blind squirrel finds a nut now and then. :D
