[SOLVED] Rotary Encoder Position not sending via LoRa
Greetings,
I am somewhat of a beginner. I am currently using two MKR 1310s as a transmitter and receiver. I am attempting to send distance data by using a Taiss E38S6-100-24G Rotary Encoder to the receiver.
When I observe the serial monitor of the transmitter, the count of the rotations works flawlessly.
My Problem:
I am able to see seemingly appropriate data on the receiver serial monitor but the rotation/distance number stays at whatever number the transmitter was on when I switched ports. When I switch ports back to the Tx'er, it continued to track accurately.
Serial Monitor Example:
//Tx serial monitor //
LoRa Sender
Rotations: 0
Rotations: 4
Rotations: 26
Rotations: 48
Rotations: 54
//Switch from Tx serial monitor and connect to rx //
LoRa Reciever
Rotations: 54
Rotations: 54
Rotations: 54
Rotations: 54
// Reconnect to Tx serial monitor //
LoRa Sender
Rotations: 59
Rotations: 72
Rotations: 84
Rotations: 109
// Reconnect to Rx serial monitor //
LoRa Reciever
Rotations: 54
Rotations: 54
Rotations: 54
Rotations: 54
My code:
[code]
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
//Constants
#define encoder0PinA 0
#define encoder0PinB 1
//Variables
int encoder0Pos = 0;
int valRotary, lastValRotary;
  // Initialize encoder pins
  pinMode(encoder0PinA, INPUT_PULLUP);
  pinMode(encoder0PinB, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
  while (!Serial);
  Serial.println("LoRa Sender");
  if (!LoRa.begin(915E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  attachInterrupt(0, doEncoder, CHANGE); //Interupt from pin 0
  if (valRotary > lastValRotary)
    if (valRotary);
  lastValRotary = valRotary;
  Serial.print("Rotations: ");
  Serial.print(lastValRotary);
  Serial.println(", ");
  // send packet
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on
  LoRa.beginPacket();
  LoRa.print("Rotations: ");
  LoRa.print(valRotary);
  LoRa.println(", ");
  LoRa.endPacket();
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  delay(3000);
void doEncoder()
  if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB))
    encoder0Pos++;
    encoder0Pos--;
  valRotary = encoder0Pos / 1.99; // Calibration for 100 positions per rotation
[/code]
What I think is wrong but cant figure out how to fix:
I believe my issue lies in either the interrupt or my inability to get the doEncoder() function to work inside of the loop(). Ive attempted to assign the doEncoder() function to a variable inside of loop() in a few different ways to no avail. I have also moved the interrupt around and altered it's parameters.
I think there could also be an issue with my valRotary if statements and their relation to the doEncoder() function.
I may be in over my head here. This is my first post and I hope I have included everything needed to get some hints.
Thank you!
Instead of the serial monitor and switching between ports, use a terminal program to monitor a serial port (TeraTerm, PuTTY, etc.).
That way you can monitor two or more Serial.print() data streams simultaneously.
When using a terminal program, you may have to replace the following with a delay() statement (I often use delay(2000)):
  while (!Serial);
attachinterrupt should be in setup() and not in loop()
  while (!Serial);
    while (1);
  attachInterrupt(0, doEncoder, CHANGE); //Interrupt from pin 0`
This is what I spotted right away. Let us know if it fixed the bug.
Thank you! Very Helpful. TeraTerm FTW.
Yes! I thought I had tried this, but I suppose I had the attachinterrupt() in a different place in setup(). The solved my issue. I really appreciate it!
