Hi all
I am working on a project based on RTC clock DS1307. I have been using it without any problems for a couple of months now without a problem.
this is what i used. http://www.glacialwanderer.com/hobbyrobotics/?p=12
But during the last week RTC is behaving strangely... ie) it is not running. It runs sometimes when I touch the 32khz with my fingers but whenever I remove my fingers it stops (I can assure you it is not loose connection problem). What could be the problem?? I am using a breadboard. I tried different breadboards, different Crystals, different ICs even but still problem persists...
It has to be crystal I guess... but i changed like 7-8 crystals but still nothing...
IC is fine because I can set and read time from it. Problem is that it is not "running".
Is it some ground problem of the crystal (Because something like that is mentioned in the datasheet of 1307)?? I had shorted the arduino gnd and 3V battery gnds and I am not using any capacitors...
Can someone help me fix this?? because its driving me nuts and I am pretty sure its not a wiring problem...
Thanks in advance.
Have you tried changing its battery ?
Yup.. Checked with a multimeter. VBAT pin is receiving 3V. even tried a potential divider circuit to get 3v from Arduino 5V. Even that didnt make it work ![]()
Do you have some decoupling capacitor (say .1 uF) across Vcc and Gnd near the chip??
Are you SURE ground is not flaky or bouncing on the breadboard etc? Temporarily double up wires to Ground and Vcc. There is the occasional bad manufactured-jumper wire.
I havent put a decoupling capacitor... is it necessary??
and GND is not flaky because I have wired it in different breadboards using different wires..
I have just now tried putting the .1uF between Vcc and GND of the breadboard. but still nothing... It works only when I touch it
Should I specifically place the capacitor at some place? or put any capacitors for crystals??
Wow, everything is right and it still doesn't work..
This simply means there is something else we don't understand...
Ideas anyone??
Do you have pull-up resistors??
Have you tried another Arduino??
Hmmm....
yup. Pull up resistance used are 2.2k and connected as given in http://www.glacialwanderer.com/hobbyrobotics/?p=12
and yes I checked with another arduino still works only when I touch. ![]()
Cant figure out why its working erratically and its driving me nuts... =(
Upload a picture of how you were touching the crystal on the cap or across the leads?
The Maxim DS1307 data sheet shows a recommended layout for the crystal in Figure 2. This would imply that not only are the electrical characteristics of the crystal important but so is the physical layout. I have successfully used a pc board layout that did not include the recommended ground plane, but a solderless breadboard introduces a lot of extraneous capacitance which may be your problem.
Don
I am touching the metal cap on top not the leads... and touching always doesnt make it run (Abt 80% of the time when I touch it runs) and that too not always at the correct speed..
I too am guessing this to be the reason... any way to correct this??
000:
- Ok, that is a bit strange.
- Use a perf board to build your circuit on or a PCB kit?
Like this:
or this:
This is my version ![]()
My guess is that crystal capacitance does not match the DS1307 requirements.
What is the Cl of the crystal? Verify that this matches the DS1307 requirements.
Does the ESR specification of the crystal match the drive capabilities
of the DS1307? Both of these specifications are important for stable operation.
For low frequency crystals I use a guard ring around the crystal. These
devices are high-impedance and are susceptible to noise.
Pictures of my layouts are at Loading...
(* jcl *)
How do I find this? because I I got the crystals from a local shop and no way to know the values... I still am thinking its the capacitance problem of the crystals..
By the way what is CI and ESR?
I tried building on General purpose line PCB board earlier but it didnt work same problem... but I will give it a try once more...
Cant use/order pref board its too expensive for the stuff I am building considering the shipping charges...
Cl is load capacitance. For the DS1307 the required load capacitance is 12.5pF.
This capacitance is internal to the DS1307.
ESR is Effective Series Resistance. For the DS1307 the maximum ESR is 45KOhms.
These values effect startup and stability of the clock. You need the datasheet
for the crystal to get these numbers. If your layout is correct (see the MAXIM
datasheet) the best thing to do is to order a couple of crystals from Mouser
or Digikey.
(* jcl *)
thanx... I guess i will try changig the crystals then... ![]()
I've used this from dipmicro.com without any problem:
http://dipmicro.com/store/XC4-32768
The load capacitance is 12.5pF. The effective serial resistance is not given though. And it's out of stock.
Thanx u guys
appreciate the help but ordering such a small thing online is very expensive
Lemme try a few other local shops here ![]()
000:
Thanx u guysappreciate the help but ordering such a small thing online is very expensive
You in USA by any chance?
nope. All the way in India. Here price of the crystal in the shop is half of what is given in the link u gave just now ![]()
