Decoded,SAMSUNG:,B24D7B84(32,bits)
#define,Something_DEC,2991422340
#define,Something_HEX,B24D7B84
Raw,(100):
{4400,4300,600,1550,550,550,550,1550,550,1600,550,500,600,500,600,1500,550,550,600,450,600,1550,550,500,600,500,600,1500,550,1600,550,500,600,1550,550,500,600,1550,550,1550,600,1550,600,1550,600,450,600,1550,600,1550,550,1600,550,500,550,500,600,500,550,500,600,1550,550,500,600,500,550,1550,600,1550,550,1600,550,500,550,550,550,500,550,500,600,500,550,500,600,500,550,500,600,1550,550,1550,600,1550,550,1600,550,1550,600};
Decoded,SAMSUNG:,B24D1FE0(32,bits)
#define,Something_DEC,2991398880
#define,Something_HEX,B24D1FE0
Raw,(100):
{4400,4300,600,1550,550,500,600,1550,550,1600,600,450,600,450,600,1550,550,500,600,500,600,1550,550,500,550,500,600,1550,550,1600,550,500,550,1600,550,500,600,500,550,500,550,1600,550,1550,600,1550,550,1600,550,1550,600,1550,550,1550,600,1550,600,450,600,500,600,450,600,500,550,500,600,1550,600,1550,550,500,600,1550,600,1500,600,500,550,500,600,500,550,500,600,450,600,1550,600,450,600,500,600,1550,550,1550,600,1550,550};
above are the codes received by my Arduino receiver circuit…
I am using IRremote library in arduino MEGA 2560
my reciever is TSOP something 38… I KNOW it recieves 38 khz…
And below are the attached codes I used for receiving and transmitting the codes…
The circuit works fine . I know this because I tested a PANASONIC Encoded AC and transmitted the RAW data perfectly using irsend.sendraw command from irremote library
What am I doing Wrong??
I even deleted the first value obtained in the SERIAL OUTPUT and removed all the minus signs…
I tried to run it on frequencies from 0 - 500 khz using khz ++ and delay of 500 ms…
KINDLY HELP PLEASE…
I am stuck in it for more than a week now…
ANY HELP WILL BE APPRECIATED
RAW_CODE_SEND_ON_OFF.ino (3.36 KB)
IR_RECV_MAYBE_MODIFIED.ino (2.22 KB)
