I connect the sd-card module pins with arduino mega:
cs -> 53
mosi -> 51
sck ->52
miso ->50
GND -> GND
5V -> 5V
the compiler doesn't display any errors..and I uploaded the code.Everything is okay,but when I open the serial monitor this message appears
//error opening file....
This is the code:
#include <SD.h>
#include <SPI.h>
int CS_PIN = 53;
File file;
initializeSD();
createFile("test.txt");
writeToFile("This is sample text!");
closeFile();
openFile("prefs.txt");
Serial.println(readLine());
closeFile();
void initializeSD()
Serial.println("Initializing SD card...");
pinMode(CS_PIN, OUTPUT);
if (SD.begin())
Serial.println("SD card is ready to use.");
} else
Serial.println("SD card initialization failed");
return;
int createFile(char filename[])
file = SD.open(filename, FILE_WRITE);
if (file)
Serial.println("File created successfully.");
return 1;
} else
Serial.println("Error while creating file.");
return 0;
int writeToFile(char text[])
if (file)
file.println(text);
Serial.println("Writing to file: ");
Serial.println(text);
return 1;
} else
Serial.println("Couldn't write to file");
return 0;
void closeFile()
if (file)
file.close();
Serial.println("File closed");
int openFile(char filename[])
file = SD.open(filename);
if (file)
Serial.println("File opened with success!");
return 1;
} else
Serial.println("Error opening file...");
return 0;
String readLine()
String received = "";
char ch;
while (file.available())
ch = file.read();
if (ch == '\n')
return String(received);
received += ch;
return "";
The image of serial monitor is in 2.png.
Can you help me please?! Thank you.
