Hi there.
I’m quite new to the arduino programming. I am using a Seeeduino Stalker v2.2 with a Bluetooth Bee (WLS125E1P) module placed directly on the bee series socket on the stalker. the board is connected to pc via uartsbee (see attachment 1). I tried that wiki sample code (just some serial outputs modified) believing pins 1 and 2 should be the right ones (after trying unmodified sample code with pins 11/12 → not working):
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 1
#define TxD 2
#define DEBUG_ENABLED 1
SoftwareSerial blueToothSerial(RxD,TxD);
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
//Typical Bluetoth command - response simulation:
//Type 'a' from PC Bluetooth Serial Terminal
//See Bluetooth Bee - Wiki for instructions
if(blueToothSerial.read() == 'a')
blueToothSerial.println("You are connected");
//You can write you BT communication logic here
void setupBlueToothConnection()
Serial.print("Setting up bluetooth bee..");
blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
// blueToothSerial.begin(115200); //Set BluetoothBee BaudRate
sendBlueToothCommand("\r\n+STWMOD=0\r\n");
sendBlueToothCommand("\r\n+STNA=AP_BB\r\n");
sendBlueToothCommand("\r\n+STAUTO=0\r\n");
sendBlueToothCommand("\r\n+STOAUT=1\r\n");
sendBlueToothCommand("\r\n +STPIN=0000\r\n");
delay(2000); // This delay is required.
sendBlueToothCommand("\r\n+INQ=1\r\n");
//Checks if the response "OK" is received
void CheckOK()
char a,b;
while(1)
if(blueToothSerial.available())
Serial.print("Available..");
a = blueToothSerial.read();
Serial.println(a);
if('O' == a)
// Wait for next character K. available() is required in some cases, as K is not immediately available.
while(blueToothSerial.available())
b = blueToothSerial.read();
//Serial.println(b);
if('K' == b)
//Serial.print("Ok");
while( (a = blueToothSerial.read()) != -1)
//Wait until all other response chars are received
void sendBlueToothCommand(char command[])
Serial.print(command);
blueToothSerial.print(command);
CheckOK();
you can see the output in attachment 2 (“ending” with an infinite “Available…x” loop…). what am i doing wrong? wrong pins? if yes… which are the right pins (and how can i determine the right pins next time)? can i use the bluetooth bee directly on that bee socket or have i to use a bees shield?
i hope someone can help me or at least give me some hints.
I tried that wiki sample code (just some serial outputs modified) believing pins 1 and 2 should be the right ones (after trying unmodified sample code with pins 11/12 -> not working):
Did you mean pins 0 and 1?
If so, your code doesn't reflect that. And, you can't do SoftwareSerial on the hardware serial pins. Especially while still trying to do hardware serial on them.
A link to the shield you are using would be useful. If the manufacturer supplies sample code that says that the bluetooth device is connected to some pins, I think I'd accept the fact that the device IS connected to those pins.
but arent these pins used for the serial communication with my pc (connected to pc via http://www.seeedstudio.com/wiki/UartSBee_V4? so it occures to me like i cant use the bee socket when the board is connected to my pc? i am confused.. im sorry if these question sounds stupid - as i mentioned i am quite new to arduino.
Yes, they are.
You get to choose which device (PC or bluetooth) you want to talk to. Both is not an option. With that board, anyway. The XBee shields I have allow selecting which pins (0 and 1 or 2 and 3) to use. Not perfect, since those are the external interrupt pins, but better than the "screw you, we'll tell you which pins to use" shield you have.
Not at all. What's stupid is the lack of choice built into the shield.
Thanks this was my problem as well, switching from using the softwareserial ports to the hardware 0/1 ports using the following code fixed my comms with the bee. In the stalker v3 it looks like you can switch from ports 0/1 to 6/7 by cutting a pad (see http://www.seeedstudio.com/wiki/Seeeduino-Stalker_v3).
// this is the pin on the micro that is connected to the tx pin on the bluetooth bee
define BlueToothReceivePin 0
// this is the pin on the micro that is connected to the rx pin on the bluetooth bee
define BlueToothTransmitPin 1
Serial.begin(38400); //Set BluetoothBee baud rate to default value
Serial.print(command); // Use hardware serial port
delay(3000);
