[SOLVED] "Send tweet with timestamp" sketch hangs, shows no activity
I cleaned up the code and got rid of the String class but I still get the same problem: when I press the button again to send a second tweet, the code starts to run but gets hung up in the sendNTPpacket() method at the Udp.endPacket(); statement.
new code:
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
#include <Twitter.h>
#include <EthernetUdp.h>
#include <stdlib.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
#define LED_red 5    // the pin for the red LED
#define LED_grn 6    // the pin for the green LED
#define BUTTON 7     // input pin of the pushbutton
int btn_val = 0;     // stores the state of the input pin
int shop_status = 0;  // 0 = We're currently CLOSED
                      // 1 = We're currently OPEN
// Ethernet Shield Settings
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
// byte ip[] = { 192, 168, 2, 250 };
unsigned int localPort = 8888;      // local port to listen for UDP packets
IPAddress timeServer(192, 43, 244, 18); // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter("you-shall-not-pass");
// Messages to post
  char msgOpen[] = "We're open";       // 11 chars
  char msgClosed[] = "We're closed";   // 13 chars
  char tweet[141];                      // The tweet to send
  char timestamp[8];
  pinMode(LED_red, OUTPUT);    // tell Arduino LED_red is an output
  pinMode(LED_grn, OUTPUT);    // tell Arduino LED_grn is an output
  pinMode(BUTTON, INPUT);      // tell Arduino BUTTON is an input
  Ethernet.begin(mac);
  Udp.begin(localPort);
  Serial.print("Ready! btn_val: ");
  btn_val = digitalRead(BUTTON);          // read input value and store it fresh
  Serial.println(btn_val);
  // check if button has been pressed
  if ((btn_val == HIGH)) {
    if (shop_status == 0) {              // we were closed but now we're OPENING
       Serial.print("shop_status: ");
       Serial.println(shop_status);
       Serial.println("We're closed. Time to OPEN!");
       Serial.println("");
       strcpy(tweet, msgOpen);
    } else {                             // else shop_status == 1, which means we were open but now we're CLOSING
       Serial.println("We're open. Time to CLOSE!");
       Serial.println("");
       strcpy(tweet, msgClosed);
       boolean gotTime = getTime();    // returns TRUE if timestamp was created successfully
       if (gotTime) {                   // == 1, then the timestamp was created successfully
         strcat(tweet, " as of ");
         strcat(tweet, timestamp);
       }                                // ELSE returned 0, send tweet w/o timestamp
       strcat(tweet, "!");
       sendTweet(tweet);
       Serial.print("Tweet successfully sent: ");
       Serial.println(tweet);
//       shop_status = 1 - shop_status;
       if (shop_status){                // == 1, then we're now OPEN
         digitalWrite(LED_grn, HIGH);    // Turn green LED on
         digitalWrite(LED_red, LOW);     // Turn red LED off
       } else {                        // == 0, then we're now CLOSED
         digitalWrite(LED_grn, LOW);    // Turn green LED off
         digitalWrite(LED_red, HIGH);     // Turn red LED on
    delay(60000);                        // one minute required by website
boolean getTime() {
  Serial.println("getTime() begins!");
  Serial.println("");
  int hour = 0;
  int timezone = -7;   // AZ timezone is UTC-7.
  Serial.println("Moving to sendNTPpacket()!");
  Serial.println("");
  sendNTPpacket(timeServer); // send an NTP packet to a time server
  Serial.println("Back to getTime()!");
  // wait to see if a reply is available
  if ( Udp.parsePacket() ) {
    // We've received a packet, read the data from it
    Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    int hour24 = ((epoch % 86400L) / 3600) + timezone; // print the hour (86400 equals secs per day).
    if (hour24 < 0)
      hour24 += 24;
    if (hour24 == 0)
        hour = 12;
    else if (hour24 <= 12)
        hour = hour24;
        hour = hour24 - 12;
    int minute = (epoch % 3600) / 60;
    // build the timestamp
    char hourStr [3];
    char minStr [3];
    itoa(hour, hourStr, 10);
    itoa(minute, minStr, 10);
    strcpy(timestamp, hourStr);
    if (minute < 10)
      strcat(timestamp, ":0");
      strcat(timestamp, ":");
    strcat(timestamp, minStr);
    if (hour24 < 12)
      strcat(timestamp, "am");
      strcat(timestamp, "pm");
  Serial.print("Current time: ");
  Serial.println(timestamp);
  return 1;                                        // add return 0;
void sendTweet(char* msg) {                        // change to boolean
  Serial.println("sendTweet() begins!");
  if (Ethernet.begin(mac) == 0) {                           //move this
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)                                                     // BAD!
      Serial.println("infinite loop!");
  Serial.println("connecting ...");
  if (twitter.post(msg)) {
    // Specify &Serial to output received response to Serial.
    // If no output is required, you can just omit the argument, e.g.
    // int status = twitter.wait();
    int status = twitter.wait(&Serial);
    if (status == 200) {
      Serial.println("OK.");
      Serial.print("failed : code ");
      Serial.println(status);
    Serial.println("connection failed.");
  Serial.println("sendTweet() ENDING!");
  Serial.println("");
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
  Serial.println("sendNTPpacket() begins!");
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  Serial.println("memset set!");
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
    Serial.println("adding to packetBuffer!");
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
    Serial.println("packetBuffer set!");
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
    Serial.println("beginPacket set!");
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
    Serial.println("write set!");
  Serial.print("NTP_PACKET_SIZE: ");
  Serial.println(NTP_PACKET_SIZE);
  Udp.endPacket();                              // << Code hangs here when I try to send a second tweet
  Serial.println("packet ended!");
  Serial.println("sendNTPpacket() ENDING!");
  Serial.println("");
